I have my mailcow server up and running for year or more with no problems.
Now i need add traefik reverse proxy.
I’ve configured Traefik and humenius/traefik-certs-dumper.
my mailcow UI work ok with traefik ssl cert but email clients get old outdated cert and i cant figure out why its happend.
and yes i know that i need to restart mailcow services which looks like the simplest answer but it didnt help
docker restart $(docker ps -qaf name=postfix-mailcow)
docker restart $(docker ps -qaf name=nginx-mailcow)
docker restart $(docker ps -qaf name=dovecot-mailcow)
httpbind ports changed and letsencrypt skiped in mailcow.conf
SKIP_LETS_ENCRYPT=y
HTTP_BIND=127.0.0.1
HTTP_PORT=8080
HTTPS_BIND=127.0.0.1
HTTPS_PORT=8443
my mailcow docker-compose.override.yml
`version: '2.1'
services:
    nginx-mailcow:
      networks:
        web:
      labels:
        - traefik.enable=true
        - traefik.http.routers.moo.rule=Host(`${MAILCOW_HOSTNAME}`)
        - traefik.http.routers.moo.tls=true
        - traefik.http.routers.moo.tls.certresolver=production
        - traefik.http.services.moo.loadbalancer.server.port=${HTTP_PORT}
        - traefik.http.routers.moo.entrypoints=websecure
        - traefik.docker.network=web
    certdumper:
        image: humenius/traefik-certs-dumper:latest
        container_name: traefik_certdumper
        network_mode: none
        command: --restart-containers mailcow_postfix-mailcow_1,mailcow_dovecot-mailcow_1,mailcow_nginx-mailcow_1
        volumes:
          - /etc/localtime:/etc/localtime:ro
          - /opt/traefik/data/ssl-certs:/traefik:ro
          - ./data/assets/ssl/:/output:rw
        environment:
          - DOMAIN=${MAILCOW_HOSTNAME}
networks:
  web:
    external: true`
my traefik docker-compose
`version: '3'
services:
  traefik:
    image: "traefik:v2.5"
    container_name: "traefik"
    networks:
      - web
    ports:
      - "80:80"
      - "443:443"
      # (Optional) Expose Dashboard
      #- "8080:8080"  # Don't do this in production!
    volumes:
      - /opt/traefik:/opt/traefik
      - ./data/ssl-certs:/ssl-certs
      - ./data/traefik.yml:/traefik.yml:ro
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.traefik.tls=true"
      - "traefik.http.routers.traefik.tls.certresolver=production"
      - "traefik.http.routers.traefik.rule=Host(`traefik.domain.eu`) && (PathPrefix(`/api`) || PathPrefix(`/dashboard`))"
      - "traefik.http.routers.traefik.service=api@internal"
      - "traefik.http.routers.traefik.middlewares=auth"
      - "traefik.http.middlewares.auth.basicauth.users=admin:*****************************************"
networks:
  web:
    external: true
my traefik.yml
`global:
checkNewVersion: true
sendAnonymousUsage: false # true by default
api:
dashboard: true # true by default
entryPoints:
web:
address: :80
(Optional) Redirect to HTTPS
http:
redirections:
entryPoint:
to: websecure
scheme: https
websecure:
address: :443
certificatesResolvers:
staging:
acme:
email: ***@gmail.com
storage: /ssl-certs/acme.json
caServer: “https://acme-staging-v02.api.letsencrypt.org/directory”
httpChallenge:
entryPoint: web
production:
acme:
caServer: “https://acme-v02.api.letsencrypt.org/directory”
httpChallenge:
entryPoint: web
providers:
file:
filename: dynamic.yml
docker:
exposedByDefault: false # Default is true`
    • Best Answerset by xbyte
    I ran the mailcow update again and it fixed everything.
    The problem is completely solved, but I really want to understand what was wrong.
    If anyone can explain what was wrong, or at least tell me what could be wrong, I’d really appreciate it
after updating mailcow to a newest ver i got new error
bash helper-scripts/expiry-dates.sh
unable to load certificate
140659514230080:error:0909006C:PEM routines:get_name:no start line:../crypto/pem/pem_lib.c:745:Expecting: TRUSTED CERTIFICATE
TLS expiry dates:
Postfix: Dec 31 16:55:58 2021 GMT
Dovecot:
Nginx: Apr 2 21:19:08 2022 GMT
