- Edited
Hi, i have a question on usage certificat ssl on server mailcow, my server has a warning on certificat because this is verified by mailcow. I can have it verified by let’s encrypt?
Thank you for your help.
English
by default the certificate is verified by mailcow?
excuse me i don’t understand how to generate a ssl certificate without mailcow being the certificate authority
check the logs, because the certificates from LE should be created for you automatically
docker-compose logs acme-mailcow
There was a problem with a recent ACME container image which caused the error for the missing openssl.cnf
file you are seeing: mailcow/mailcow-dockerized4392
Try pulling the images again and check if this helps.
