BusterB Hi, sorry for late reply
Um the good news is i’m now sure it’s problem with my 25 port the bad news is it seems it works fine?
root@debian:~# telnet 192.168.0.101 25
Trying 192.168.0.101...
Connected to 192.168.0.101.
Escape character is '^]'.
220-mail.esmailelbob.xyz ESMTP Postcow
220 mail.esmailelbob.xyz ESMTP Postcow
because i got Delayed Mail (still being retried)
This is the mail system at host mail.esmailelbob.xyz.
# THIS IS A WARNING ONLY. YOU DO NOT NEED TO RESEND YOUR MESSAGE. #
Your message could not be delivered for more than 4 hour(s).
It will be retried until it is 5 day(s) old.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<test-k91q5asu6@srv1.mail-tester.com>: connect to
reception.mail-tester.com[94.23.206.89]:25: Connection timed out
so yes it’s problem with my 25 port but for some reason when i check it out online or via telnet it works fine so maybe problem elsewhere?
about Routing -> Sender-Dependent Transports i’m not sure what to do there so could you explain more?
about queue manager yes all of my sent emails i have the word deferred on them
about logs i get no warnings when i send email except i get connect to smtp2.mailfence.com[212.3.242.79]:25: Connection timed out
Last but not least about dns i have the recommend dns for me that are in config -> mail setup -> action (DNS) although i have error with one of dns record in TSLA dns i get php error but yes you can help me and give me dns records as example so i mimic them for my server
PS: when i try to telnet it it hangs out so something in my machine that does not allow 25 ports? but i do not have firewall tho
root@debian:~# telnet smtp1.mailfence.com 25
Trying 212.3.242.78...
