Proxido Hello, In Sogo’s preferences screen there is an option to enable two-factor authentication using google authenticator. However when I check the chekcbox nothing happens, no key is displayed. Does it work for anyone?
jzadir It’s fully implemented; The only missing part is the qrcode.js All you have to do is download the qrcode.js, place it on the WebServerResources directory and load it with SOGoUIAdditionalJSFiles directive. that can be verified in https://github.com/inverse-inc/sogo/blob/e8f0471bcfe8516fdb1afb1efcc34e9c4053e9ee/UI/WebServerResources/js/Common/sgQrCode.directive.js
diekuh There has not yet been a stable package with tfa. Why do you assume the code is 100% complete? Am I missing something?
MAGIC Will probably in the next release, because work on 2FA has been started after the latest release when I check the commits https://github.com/inverse-inc/sogo/compare/SOGo-4.3.2...master
abyss02 Just my 2 cents: Great news … i searched this topic and sogo is supporting 2fa now with version 5.0.0 …. if anyone looks for the same topic …. But is there a possibility to get the totp-code an not the qr-code?
pkernstock abyss02 ut is there a possibility to get the totp-code an not the qr-code? Yes, mailcow also now ships with SOGo 5. If there are any specific questions to SOGo or its implementation or settings, please raise the question directly at the SOGo project.
