I’m trying to connect to https and it’s using a self signed cert which isn’t working.
my DNS is setup for mx smtp.mydomain.com and smtp.mydomain.com points to my server
spf and dkim work fine.
when i open http://smtp.mydomain.com i get the mailcow login page, but when i open https://smtp.mydomain.com i get ERR_CERT_INVALID, and when i check the cert details it says the issuer is mailcow.
I’ve uncommented ADDITIONAL_SAN=imap.*,smtp.* and commented out the line ADDITIONAL_SAN=
I’ve also tried touching data/assets/ssl/force_renew which doesn’t seem to do anything, and the docs say it should get automatically removed, but it doesn’t.
finally here’s my acme log:
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Waiting for Docker API...
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Docker API OK
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Waiting for Postfix...
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Postfix OK
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Waiting for Dovecot...
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Dovecot OK
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Waiting for database...
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Database OK
acme-mailcow_1 | Thu Dec 9 04:23:15 PST 2021 - Waiting for Nginx...
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Nginx OK
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Waiting for resolver...
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Resolver OK
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Waiting for domain table...
acme-mailcow_1 | OK
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Initializing, please wait...
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow_1 | Thu Dec 9 04:23:16 PST 2021 - Detecting IP addresses...
acme-mailcow_1 | Thu Dec 9 04:23:40 PST 2021 - OK: 1.1.1.1, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow_1 | Thu Dec 9 04:23:40 PST 2021 - Found A record for smtp.mydomain.com: 1.1.1.1
