louisplayz I’ve used it successfully with IP4 and it works fine. Make sure the ports aren’t conflicting with something else on the system and make sure to use the right IPs for the BIND. (I prefer not to leave those blank). The IPs should be the IPs for the host and not the container. (I’ve never tried the latter though I suppose it might work if you are on the same (docker) network.)
