Hi @all
First of all, thanks for this great mailcow dockerized project!
I have the problem that sending mails by SMTP takes a very long time.
I found several threads regarding the same problem but no solution for my problem.
- I’m connecting via SMTP on port 465 SSL/TLS (so not Port 25 to avoid this problem)
- IPv6 is not enabled and I have no public IPv6 address, so I have no AAAA record for my mail server and the PTR record is only set for the IPv4 address
- Sending mails is always slow independent of using
- SoGo
- Thunderbird on my client PC
- GMail App on Android
- Server in our company running a CRM and sending mails using PHP (here there’s sometimes even a timeout while sending)
Here’s the postfix log. This is recorded while sending an email using Thunderbird.
It shows a delay of approx. 7sec before processing the email further…
16.08.2021, 08:56:27 info C164F343F7: removed
16.08.2021, 08:56:27 info C164F343F7: to=<receivermail@gmail.com>, relay=gmail-smtp-in.l.google.com[74.125.140.27]:25, delay=13, delays=11/0.02/1.2/0.45, dsn=2.0.0, status=sent (250 2.0.0 OK 1629096987 3si10838896wry.379 - gsmtp)
16.08.2021, 08:56:26 info Trusted TLS connection established to gmail-smtp-in.l.google.com[74.125.140.27]:25: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature ECDSA (P-256) server-digest SHA256
16.08.2021, 08:56:26 info connect to gmail-smtp-in.l.google.com[2a00:1450:400c:c08::1b]:25: Network is unreachable
16.08.2021, 08:56:25 info disconnect from mail.my.tld[1.2.3.4] ehlo=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=6
16.08.2021, 08:56:25 info C164F343F7: from=<sender@my.tld>, size=3732, nrcpt=1 (queue active)
16.08.2021, 08:56:18 info C164F343F7: message-id=<644e4cb4-e5f4-7349-c21c-a932b599211e@my.tld>
16.08.2021, 08:56:18 info C164F343F7: replace: header Received: from [172.21.0.36] (mail.my.tld [1.2.3.4])??(using TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)?? key-exchange X25519 server-signature RSA-PSS (2048 bits))??(No client cer from mail.my.tld[1.2.3.4]; from=<sender@my.tld> to=<receivermail@gmail.com> proto=ESMTP helo=<[172.21.0.36]>: Received: from [127.0.0.1] (localhost [127.0.0.1]) by localhost (Mailerdaemon) with ESMTPSA id C164F343F7??for <receivermail@gmail.com>; Mon, 16 Aug 2021 08:56:14 +0200 (CEST)
16.08.2021, 08:56:18 info C164F343F7: client=mail.my.tld[1.2.3.4], sasl_method=PLAIN, sasl_username=sender@my.tld
16.08.2021, 08:56:14 info Anonymous TLS connection established from mail.my.tld[1.2.3.4]: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits)
16.08.2021, 08:56:14 info connect from mail.my.tld[1.2.3.4]
16.08.2021, 08:56:03 info statistics: max cache size 1 at Aug 16 08:52:37
Any help is greatly appreciated.
Best regards
Bastian
