The script ran fine, I only caught this error:
Fetching new images, if any...
ERROR: Named volume "xmpp-vol-1:/home/ejabberd/database:z" is used in service "ejabberd-mailcow" but no declaration was found in the volumes section.
Checking IPv6 settings...
Starting mailcow...
Collecting garbage...
after the update was finished no contaienr was running. trying t docker-compose up -d resulted in this error:
I need some advice please. i don’t use ejabberd at all - waht to do?
  • sorry I dropped the ball but I must have missed the email notification about your reply. Unfortunately its too long ago and I can’t remember, lets drop this issue for now.
to get mailcow up and running again I have added the volumes at the end of the docker-compose.yml file but how did this happen? as far as I know the upgrade.sh script also updates docker-compose.yml so how come?
volumes:
  vmail-vol-1:
  vmail-index-vol-1:
  mysql-vol-1:
  mysql-socket-vol-1:
  redis-vol-1:
  rspamd-vol-1:
  solr-vol-1:
  postfix-vol-1:
  crypt-vol-1:
  sogo-web-vol-1:
  sogo-userdata-backup-vol-1:
  xmpp-vol-1:
  xmpp-upload-vol-1:
ovizii changed the title to Problems after running update.sh .
  • MAGIC
    • Forum Staff
    • volunteer
    Moolevel 48
Hm that’s odd yes. Do you know when you did the last update?
13 days later
