Hi there, i have succesfully installed Mailcow mailserver.
coming from a manual installed server with nextcloud installed i wanted to have nextcloud again.
i have seen, that there is a helperscript which is supposed to install nextcloud.
since i am am very new with docker, i hope this question is not too stupid.
i have used the helperscript to install nextcloud and set it to use “cloud.mydomain.de”. after a seemingly succsessfull install i cannot reach cloud.mydomain.de because the ssl cert (wich was created by mailcow (mail.mydomain.de)) has a valid domain of mail.mydomain.de.
how can i reach the nextcloud install - or how can i create a new cert for cloud.mydomain.de?
Thank you so much,
Pcace
    • Best Answerset by pcace
    Ok. Please ignore the whole question…
    The Problem was, that i had some wrong DNS records set….
    So - Problem solved!
Hi, thanks for your reply!
i have now added cloud.mydomain.de to ADDITIONAL_SAN.
after i ran docker-compose up -d nothing changed. i still have a wrong ssl cert when opening cloud.mydomain.de…
i think i dont quit understand what i should do there… :/
maybe you have any further advice?
Thanks!!!
PS.: do i have to have cloud.mydomain.de in the server DNS records? (because i still have it there…)
