Hello everyone,
I’m running mailcow-dockerized on Ubuntu 26.04.1 LTS and have been investigating possible mitigations for the recently disclosed Linux kernel vulnerability CVE-2026-98432.
Since mailcow uses Docker containers that share the host kernel, I wanted to ask how other mailcow administrators are handling this issue while waiting for patched kernels.
My environment:
Ubuntu 26.04.1 LTS
Linux kernel 7.0.0-38-generic
Docker Engine 28.1.1
Docker bridge networking
iptables-nft with UFW enabled
What I found:
All 17 bridge-networked mailcow containers had net.mptcp.enabled=1.
Disabling MPTCP on the host did not disable it inside the containers, because each uses a separate network namespace.
I disabled MPTCP in the running containers using nsenter.
I added an independent nftables PREROUTING rule on the host to drop IPv4 TCP packets containing IP Options, using priority -310.
Normal mail sending and receiving continued working after these changes.
I have also prepared a docker-compose.override.yml with the appropriate sysctls for the 17 containers. The merged Compose configuration validates successfully, but I have not recreated the containers yet.
Questions:
Are other mailcow administrators taking similar precautions?
Is disabling MPTCP separately in each container considered necessary or useful for this vulnerability?
Are there any mailcow-specific concerns with the host-level nftables mitigation, especially regarding the netfilter container?
Would the mailcow team recommend any additional precautions?
Would the maintainers consider recommending net.mptcp.enabled=0 in the default Docker Compose configuration as a temporary mitigation, or should this remain an administrator-level decision?
I understand that updating to a fixed host kernel is the ultimate solution. These are temporary mitigations, and I have not verified their effectiveness against an actual exploit.
References:
Ubuntu Security: https://ubuntu.com/security/CVE-2026-98432
Linux kernel documentation (MPTCP): https://docs.kernel.org/networking/mptcp-sysctl.html
Docker Compose documentation (sysctls): https://docs.docker.com/reference/compose-file/services/#sysctls
I’d appreciate any feedback or experiences from other administrators.
Thanks!
