esackbauer
The entries above had spaces so I changed it to spaces.
Do I need to restart the container for it to take affect?
Also what is your opinion on using crowdsec? After looking at the logs after a reboot I see this and I think crowdsec it causing this message:
08/02/2026, 10:08:27 MAILCOW target is in position 2 in the ip input table, restarting container to fix it...
08/02/2026, 10:08:29 Allowlist was changed, it has 1 entries
08/02/2026, 10:08:29 Watching Redis channel F2B_CHANNEL
08/02/2026, 10:09:19 MAILCOW target is in position 2 in the ip6 input table, restarting container to fix it...
08/02/2026, 10:09:22 Allowlist was changed, it has 1 entries
08/02/2026, 10:09:22 Watching Redis channel F2B_CHANNEL
08/02/2026, 10:09:42 MAILCOW target is in position 2 in the ip6 input table, restarting container to fix it...
08/02/2026, 10:09:44 Allowlist was changed, it has 1 entries
08/02/2026, 10:09:44 Watching Redis channel F2B_CHANNEL
08/02/2026, 10:10:14 MAILCOW target is in position 2 in the ip input table, restarting container to fix it...
08/02/2026, 10:10:16 Allowlist was changed, it has 1 entries
