Dear all,
unfortunately I couldn`t get it running in the first place; so any help is appreciated.
Given:
Mailcow-Hostname: mx.mailcow.email
I would like to add a static site for the “base-domain”; e.g. at mailcow.email or www.mailcow.email.
(Background: I would like to set-up a short Imprint-Site (alongside the footer on all login-pages) for t-online.de-Postmasters)
Tried the following to no avail:
I used 2 different nginx-conf-Files.
1) For mailcow.email:
server {
ssl_certificate /etc/ssl/mail/cert.pem;
ssl_certificate_key /etc/ssl/mail/key.pem;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305;
ssl_ecdh_curve X25519:X448:secp384r1:secp256k1;
ssl_session_timeout 1d;
ssl_session_tickets off;
index index.php index.html;
client_max_body_size 0;
# Location: data/web
root /web;
# Location: data/web/mailcow.email
root /web/mailcow.email
include /etc/nginx/conf.d/listen_plain.active;
include /etc/nginx/conf.d/listen_ssl.active;
server_name mailcow.email;
server_tokens off;
# This allows acme to be validated even with a different web root
default_type "text/plain";
rewrite /.well-known/acme-challenge/(.*) /$1 break;
root /web/.well-known/acme-challenge/;
if ($scheme = http) {
return 301 https://$server_name$request_uri;
2) For www.mailcow.email:
server {
root /web;
server_name www.mailcow.email;
server_tokens off;
