Hallo,
ich bekomme folgende Error Nachrichten in den Logs. Leider kann ich damit nichts anfangen.
Sollte das behoben werden?
Ich hatte jetzt eine zeitlang Mailcow mit folgenden Einstellungen laufen, um Ressource zu sparen. Hab aber jetzt beides auf n gesetzt.
# Skip Olefy (olefy-mailcow) anti-virus for Office documents (Rspamd will auto-detect a missing Ole>
SKIP_OLEFY=y
# Skip SOGo: Will disable SOGo integration and therefore webmail, DAV protocols and ActiveSync supp>
SKIP_SOGO=y
watchdog-mailcow-1 | Wed Jan 7 14:57:54 CET 2026 Unbound health level: 100% (5/5), health trend: 0
watchdog-mailcow-1 | Wed Jan 7 14:57:54 CET 2026 Primary certificate expiry check health level: 100% (7/7), health trend: 0
watchdog-mailcow-1 | Wed Jan 7 14:57:54 CET 2026 Postfix health level: 100% (8/8), health trend: 0
rspamd-mailcow-1 | 2026-01-07 14:57:54 #38(controller) <3225cd>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 0 regexps matched, 3767 regexps total, 2654 regexps cached, 0B scanned using pcre, 102B scanned total
watchdog-mailcow-1 | Wed Jan 7 14:57:54 CET 2026 Rspamd health level: 100% (5/5), health trend: 0
ofelia-mailcow-1 | 2026-01-07T14:58:00+01:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (6bdfb26d01b6)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool -v expire-sessions ${SOGO_EXPIRE_SESSION} || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00+01:00 common.go:125 ▶ NOTICE [Job "phpfpm_keycloak_sync" (39428dd23534)] Started - /bin/bash -c "php /crons/keycloak-sync.php || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00.002+01:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (3c176a2b40fa)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00.002+01:00 common.go:125 ▶ NOTICE [Job "phpfpm_ldap_sync" (6195c7ea571f)] Started - /bin/bash -c "php /crons/ldap-sync.php || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00.003+01:00 common.go:125 ▶ NOTICE [Job "dovecot_imapsync_runner" (6e8b1ef077c1)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00.004+01:00 common.go:123 ▶ WARNING [Job "dovecot_imapsync_runner" (6e8b1ef077c1)] Finished in "769.666µs", failed: false, skipped: true, error: none
ofelia-mailcow-1 | 2026-01-07T14:58:00.012+01:00 common.go:125 ▶ NOTICE [Job "sogo_ealarms" (58ca48864b47)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/cron.creds || exit 0"
ofelia-mailcow-1 | 2026-01-07T14:58:00.182+01:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (3c176a2b40fa)] Finished in "181.624221ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2026-01-07T14:58:00.277+01:00 common.go:125 ▶ NOTICE [Job "sogo_ealarms" (58ca48864b47)] Finished in "264.772181ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2026-01-07T14:58:00.352+01:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (6bdfb26d01b6)] StdErr: 2026-01-07 14:58:00.334 sogo-tool[104:104] Remove all sessions older than 480 min
ofelia-mailcow-1 | 2026-01-07 14:58:00.343 sogo-tool[104:104] No session to remove
ofelia-mailcow-1 | 2026-01-07T14:58:00.352+01:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (6bdfb26d01b6)] Finished in "351.76029ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2026-01-07T14:58:00.373+01:00 common.go:125 ▶ NOTICE [Job "phpfpm_ldap_sync" (6195c7ea571f)] Finished in "370.527913ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2026-01-07T14:58:00.378+01:00 common.go:125 ▶ NOTICE [Job "phpfpm_keycloak_sync" (39428dd23534)] Finished in "377.726238ms", failed: false, skipped: false, error: none
