Borgmatic ran flawlessly for many months, but now I’m getting the following error:
I think it’s probably just a missing package :-) The configuration files seem to be correct.
`/opt/mailcow-dockerized# docker compose exec borgmatic-mailcow borgmatic config validate
summary:
/etc/borgmatic.d/config.yaml: Error parsing configuration file
An error occurred while parsing a configuration file at /etc/borgmatic.d/config.yaml:
mapping values are not allowed here
in “<unicode string>”, line 9, column 12:
label: rsync
^ (line: 9)
Configuration validation failed
`borgmatic-mailcow-1 | Software Versions:
borgmatic-mailcow-1 | ———————————–
borgmatic-mailcow-1 | apprise 1.9.5
borgmatic-mailcow-1 | borg 1.4.3
borgmatic-mailcow-1 | borgmatic 2.0.12
borgmatic-mailcow-1 | dockercli not installed
borgmatic-mailcow-1 | composecli not installed
borgmatic-mailcow-1 | python 3.14.0
borgmatic-mailcow-1 | Time Zone: Europe/Berlin
borgmatic-mailcow-1 | Applying crontab.txt
borgmatic-mailcow-1 | Cron job set as:
borgmatic-mailcow-1 | 14 * * * * PATH=$PATH:/usr/local/bin /usr/local/bin/borgmatic –stats -v 0 2>&1
borgmatic-mailcow-1 | crond: crond (busybox 1.37.0) started, log level 8
borgmatic-mailcow-1 | crond: USER root pid 104 cmd PATH=$PATH:/usr/local/bin /usr/local/bin/borgmatic –stats -v 0 2>&1
borgmatic-mailcow-1 | /etc/borgmatic/config.yaml /etc/borgmatic.d /root/.config/borgmatic/config.yaml /root/.config/borgmatic.d: No valid configuration files found
borgmatic-mailcow-1 | summary:
borgmatic-mailcow-1 | /etc/borgmatic.d/config.yaml: Error parsing configuration file
borgmatic-mailcow-1 | An error occurred while parsing a configuration file at /etc/borgmatic.d/config.yaml:
borgmatic-mailcow-1 | mapping values are not allowed here
borgmatic-mailcow-1 | in “<unicode string>”, line 9, column 12:
borgmatic-mailcow-1 | label: rsync
borgmatic-mailcow-1 | ^ (line: 9)
borgmatic-mailcow-1 | Need some help? https://torsion.org/borgmatic/#issues
borgmatic-mailcow-1 | Received exit code 143.
borgmatic-mailcow-1 | [custom-init] Docker CLI variable not set, skipping…
borgmatic-mailcow-1 | [custom-init] No custom packages found, skipping…
Thank you in advance for your comments.
