Hi
I’m having trouble reaching postfix using ipv6.
IPV6 on host is properly configured, no issue reaching and be reached via IPV6, if I listen a port on host I can send data throug it via ipv6 only. (tested via netcat)
Seen not to be a firewall issue as with UFW disabled & netfilter container stopped the issue is still there.
IPV6 on mailcow seem properly configured, sending emails to ipv6 only servers is working fine (9/10 on https://www.email-security-scans.org/, the only issue is MTA-STS)
But with Mailcow, if a try a telnet via ipv6 on port 465, the connection times out.
If I telnet port 465 on client site and tcpdump on host I have this
host# tcpdump -vvv -i bond0 ip6 and port 465
tcpdump: listening on bond0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
10:56:12.351985 IP6 (flowlabel 0x99bb5, hlim 251, next-header TCP (6) payload length: 40) [client].40506 > [host].submissions: Flags [S], cksum 0x1d28 (correct), seq 1902229173, win 64800, options [mss 1432,sackOK,TS val 1238195374 ecr 0,nop,wscale 7], length 0
10:56:13.353711 IP6 (flowlabel 0x0e4f0, hlim 251, next-header TCP (6) payload length: 40) [client].40506 > [host].submissions: Flags [S], cksum 0x193e (correct), seq 1902229173, win 64800, options [mss 1432,sackOK,TS val 1238196376 ecr 0,nop,wscale 7], length 0
10:56:14.378433 IP6 (flowlabel 0x3c214, hlim 251, next-header TCP (6) payload length: 40) [client].40506 > [host].submissions: Flags [S], cksum 0x153e (correct), seq 1902229173, win 64800, options [mss 1432,sackOK,TS val 1238197400 ecr 0,nop,wscale 7], length 0
so connection reach the host but nothing on docker side
docker# tcpdump -vvv -i any ip6 and port 465
tcpdump: data link type LINUX_SLL2
tcpdump: listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
I can reach the port from host using local ipv6 address of the container
telnet fd4d:6169:6c63:6f77::d 465
Trying fd4d:6169:6c63:6f77::d...
Connected to fd4d:6169:6c63:6f77::d.
Escape character is '^]'.
Seem to be a docker / iptables issue but there is no entry in ufw.log or syslog while trying to connect I don’t know where to look.
I’m using ufw and ufw-docker chaifeng/ufw-docker and chaifeng/ufw-docker8
Here are my iptables
and ufw status
465 (v6) ALLOW Anywhere (v6)
172.22.1.250 110/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 110/tcp mailcowdockerized_mailcow-network
172.22.1.250 12345/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 12345/tcp mailcowdockerized_mailcow-network
172.22.1.250 143/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 143/tcp mailcowdockerized_mailcow-network
172.22.1.250 4190/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 4190/tcp mailcowdockerized_mailcow-network
172.22.1.250 993/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 993/tcp mailcowdockerized_mailcow-network
172.22.1.250 995/tcp ALLOW FWD Anywhere # allow mailcowdockerized-dovecot-mailcow-1 995/tcp mailcowdockerized_mailcow-network
172.22.1.253 25/tcp ALLOW FWD Anywhere # allow mailcowdockerized-postfix-mailcow-1 25/tcp mailcowdockerized_mailcow-network
172.22.1.253 465/tcp ALLOW FWD Anywhere # allow mailcowdockerized-postfix-mailcow-1 465/tcp mailcowdockerized_mailcow-network
172.22.1.253 587/tcp ALLOW FWD Anywhere # allow mailcowdockerized-postfix-mailcow-1 587/tcp mailcowdockerized_mailcow-network
And comparaison between a working ipv6 container and postfix
host# iptables-save | grep 465
-A POSTROUTING -s 172.22.1.253/32 -d 172.22.1.253/32 -p tcp -m tcp –dport 465 -j MASQUERADE
-A DOCKER ! -i br-mailcow -p tcp -m tcp –dport 465 -j DNAT –to-destination 172.22.1.253:465
-A DOCKER -p tcp -m tcp –dport 465 -j DNAT –to-destination 172.22.1.253:465
-A DOCKER -d 172.22.1.253/32 ! -i br-mailcow -o br-mailcow -p tcp -m tcp –dport 465 -j ACCEPT
-A ufw-user-forward -d 172.22.1.253/32 -p tcp -m tcp –dport 465 -j ACCEPT
-A ufw-user-input -p tcp -m tcp –dport 465 -j ACCEPT
-A ufw-user-input -p udp -m udp –dport 465 -j ACCEPT
=> this is not working
host# iptables-save | grep 25565
-A POSTROUTING -s 172.26.0.3/32 -d 172.26.0.3/32 -p tcp -m tcp –dport 25565 -j MASQUERADE
-A DOCKER ! -i br-2a8175cd2ac3 -p tcp -m tcp –dport 25565 -j DNAT –to-destination 172.26.0.3:25565
-A DOCKER -d 172.26.0.3/32 ! -i br-2a8175cd2ac3 -o br-2a8175cd2ac3 -p tcp -m tcp –dport 25565 -j ACCEPT
-A ufw-user-forward -d 172.26.0.3/32 -p tcp -m tcp –dpo
=> this is working
Can you help ?
Thanks in advance
