I think I have the same issue, I was just writing the following new thread, but I need to sleep soon, so can’t continue debugging rn, I hope someone has an Idea, or maybe I have more infos tomorrow.
I was updating mailcow and applied:
MAJOR UPDATES to be applied:
2025-02 - mailcow/mailcow-dockerizedreleases/tag/2025-02
2025-03 - mailcow/mailcow-dockerizedreleases/tag/2025-03
And now I get the 502 What is happening screen, inspecting the logs, I could see that the php-fpm container is waiting for sql, which wouldn’t come up. I waited a while but it did not end up working.
Fortunately I made a backup, unfortunately I rolled it back already so I can’t share the detailed logs.
I’ll update it again now and let it take some more time, maybe I wasn’t patient enough.
Maybe the database update in 2025-02 fried it, idk.
The Server is on Rocky 9 btw,
Well here is my logs:
mysql-mailcow-1 | 2025-06-28 01:01:17+02:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.11.13+mariaubu2204 started.
mysql-mailcow-1 | 2025-06-28 01:01:17+02:00 [Warn] [Entrypoint]: /sys/fs/cgroup///memory.pressure not writable, functionality unavailable to MariaDB
mysql-mailcow-1 | 2025-06-28 01:01:17+02:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
mysql-mailcow-1 | 2025-06-28 01:01:17+02:00 [Note] [Entrypoint]: MariaDB upgrade (mariadb-upgrade or creating healthcheck users) required, but skipped due to $MARIADB_AUTO_UPGRADE setting
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] Starting MariaDB 10.11.13-MariaDB-ubu2204 source revision 8fb09426b98583916ccfd4f8c49741adc115bac3 server_uid 3Pws4BgyEreCXleUPopu/Yrifj4= as process 1
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Number of transaction pools: 1
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Using SSE4.2 crc32 instructions
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Warning] mariadbd: io_uring_queue_init() failed with EPERM: sysctl kernel.io_uring_disabled has the value 2, or 1 and the user of the process is not a member of sysctl kernel.io_uring_group. (see man 2 io_uring_setup).
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Warning] InnoDB: liburing disabled: falling back to innodb_use_native_aio=OFF
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: innodb_buffer_pool_size_max=24m, innodb_buffer_pool_size=24m
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Completed initialization of buffer pool
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: File system buffers for log disabled (block size=512 bytes)
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Upgrading redo log: 96.000MiB; LSN=2443736
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: 128 rollback segments are active.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: log sequence number 2443736; transaction id 372592
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Warning] You need to use –log-bin to make –expire-logs-days or –binlog-expire-logs-seconds work.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] Server socket created on IP: ‘0.0.0.0’.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] Server socket created on IP: ‘::’.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] InnoDB: Buffer pool(s) load completed at 250628 1:01:17
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [ERROR] Incorrect definition of table mysql.event: expected column ‘definer’ at position 3 to have type varchar(, found type char(141).
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [ERROR] mariadbd: Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler.
mysql-mailcow-1 | 2025-06-28 1:01:17 0 [Note] mariadbd: ready for connections.
mysql-mailcow-1 | Version: ‘10.11.13-MariaDB-ubu2204’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
php-fpm-mailcow-1 | Waiting for SQL…
