It has happened again. Here is the output from iptables while incoming ipv4 (only) traffic to port 25 is being blocked:
root@mailcow:~# sudo iptables -L -v -n --line-numbers
Chain INPUT (policy ACCEPT 1571K packets, 112M bytes)
num pkts bytes target prot opt in out source destination
1 1571K 112M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
2 0 0 ACCEPT 17 -- eth0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:52821 /* wireguard-input-rule */
3 1571K 112M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
4 1571K 112M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
5 1571K 112M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
6 1571K 112M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
Chain FORWARD (policy DROP 0 packets, 0 bytes)
1 70821 34M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
2 55145 33M DOCKER-USER 0 -- * * 0.0.0.0/0 0.0.0.0/0
3 55145 33M DOCKER-FORWARD 0 -- * * 0.0.0.0/0 0.0.0.0/0
4 0 0 ACCEPT 0 -- eth0 wg0 0.0.0.0/0 10.123.67.0/24 ctstate RELATED,ESTABLISHED /* wireguard-forward-rule */
5 0 0 ACCEPT 0 -- wg0 eth0 10.123.67.0/24 0.0.0.0/0 /* wireguard-forward-rule */
6 0 0 MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
7 0 0 MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
8 0 0 MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
9 0 0 MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
10 0 0 MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
Chain OUTPUT (policy ACCEPT 195K packets, 6190M bytes)
Chain DOCKER (2 references)
1 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.253 tcp dpt:587
2 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.253 tcp dpt:465
3 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.253 tcp dpt:25
4 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:12345
5 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:4190
6 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:995
7 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:993
8 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:143
9 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.250 tcp dpt:110
10 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.10 tcp dpt:443
11 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.10 tcp dpt:80
12 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.249 tcp dpt:6379
13 0 0 ACCEPT 6 -- !br-mailcow br-mailcow 0.0.0.0/0 172.22.1.7 tcp dpt:3306
14 210 12600 ACCEPT 6 -- !docker0 docker0 0.0.0.0/0 172.17.0.2 tcp dpt:9001
15 0 0 DROP 0 -- !br-mailcow br-mailcow 0.0.0.0/0 0.0.0.0/0
16 0 0 DROP 0 -- !docker0 docker0 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-BRIDGE (1 references)
1 0 0 DOCKER 0 -- * br-mailcow 0.0.0.0/0 0.0.0.0/0
2 210 12600 DOCKER 0 -- * docker0 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-CT (1 references)
1 12757 2063K ACCEPT 0 -- * br-mailcow 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
2 12418 2392K ACCEPT 0 -- * docker0 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
Chain DOCKER-FORWARD (1 references)
1 55145 33M DOCKER-CT 0 -- * * 0.0.0.0/0 0.0.0.0/0
2 29970 29M DOCKER-ISOLATION-STAGE-1 0 -- * * 0.0.0.0/0 0.0.0.0/0
3 29970 29M DOCKER-BRIDGE 0 -- * * 0.0.0.0/0 0.0.0.0/0
4 18366 1365K ACCEPT 0 -- br-mailcow * 0.0.0.0/0 0.0.0.0/0
5 11394 27M ACCEPT 0 -- docker0 * 0.0.0.0/0 0.0.0.0/0
1 18366 1365K DOCKER-ISOLATION-STAGE-2 0 -- br-mailcow !br-mailcow 0.0.0.0/0 0.0.0.0/0
2 11394 27M DOCKER-ISOLATION-STAGE-2 0 -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
1 0 0 DROP 0 -- * docker0 0.0.0.0/0 0.0.0.0/0
2 0 0 DROP 0 -- * br-mailcow 0.0.0.0/0 0.0.0.0/0
1 55145 33M RETURN 0 -- * * 0.0.0.0/0 0.0.0.0/0
Chain MAILCOW (11 references)
1 0 0 DROP 0 -- * * 81.30.107.0/24 0.0.0.0/0
2 0 0 DROP 6 -- !br-mailcow br-mailcow 0.0.0.0/0 0.0.0.0/0 /* mailcow isolation */
3 0 0 DROP 0 -- * * 193.46.255.40 0.0.0.0/0
4 0 0 DROP 0 -- * * 81.30.107.0/24 0.0.0.0/0
5 15683 907K DROP 6 -- !br-mailcow br-mailcow 0.0.0.0/0 0.0.0.0/0 /* mailcow isolation */
Removing the duplicate blocking rule 5 from the chain MAILCOW removes the blockage:
root@mailcow:~# iptables -D MAILCOW 5
1 70835 34M MAILCOW 0 -- * * 0.0.0.0/0 0.0.0.0/0 /* mailcow */
2 55155 33M DOCKER-USER 0 -- * * 0.0.0.0/0 0.0.0.0/0
3 55155 33M DOCKER-FORWARD 0 -- * * 0.0.0.0/0 0.0.0.0/0
2 12422 2392K ACCEPT 0 -- * docker0 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
1 55155 33M DOCKER-CT 0 -- * * 0.0.0.0/0 0.0.0.0/0
2 29976 29M DOCKER-ISOLATION-STAGE-1 0 -- * * 0.0.0.0/0 0.0.0.0/0
3 29976 29M DOCKER-BRIDGE 0 -- * * 0.0.0.0/0 0.0.0.0/0
4 18368 1365K ACCEPT 0 -- br-mailcow * 0.0.0.0/0 0.0.0.0/0
5 11398 27M ACCEPT 0 -- docker0 * 0.0.0.0/0 0.0.0.0/0
1 18368 1365K DOCKER-ISOLATION-STAGE-2 0 -- br-mailcow !br-mailcow 0.0.0.0/0 0.0.0.0/0
2 11398 27M DOCKER-ISOLATION-STAGE-2 0 -- docker0 !docker0 0.0.0.0/0 0.0.0.0/0
1 55155 33M RETURN 0 -- * * 0.0.0.0/0 0.0.0.0/0
As you see the original universal block rule 2 have no matches during normal funtional operation of mailcow. Its the duplicate one that is suddenly matching any traffic and removing it restores incoming access.
