Thanks,
I found that the file located
/opt/mailcow-dockerized/data/conf/borgmatic/etc/config.yaml
Needs to be changed with the right information.
However, now I have the error
MyUser@mailcow.mydomain.net’s password:
Connection closed by remote host. Is borg working on the server?
rsync: Error running actions for repository
rsync: Command '(‘borg’, ‘info’, ‘–json’, ‘ssh://MyUser@mailcow.mydomain.net:22/./mailcow’)' returned non-zero exit status 81.
/etc/borgmatic.d/config.yaml: Error running configuration
/etc/borgmatic.d/config.yaml: An error occurred
summary:
An error occurred
Need some help? https://torsion.org/borgmatic/#issues
I left everything as-is for the repositories. Do I need to change or do something ?
Thanks
