nicedevil007 Do you have a firewall on the host which is blocking the update checks?
nicedevil007 in a prior version I was able to click on the version itself and it showed me a small changelog. This feature seems to be gone is that right?
No, it’s still there, but I guess it’s missing because of mailcow not being able to do the update check for you…
EDIT: I have to add that I’m not sure if it’s mailcow or the browser which is checking the updates, would need to dig in the source code for that
