The reason everything was deleted is that I couldn’t log in as admin through the usual method due to some disruptive actions. It later turned out that there’s an admin interface at /admin, which I wasn’t aware of. Since then, the mail service has been completely non-functional. The new system seems to have a total shit configuration with Dovecot and MySQL. I’ve tried reinstalling it about 50 times, and it still doesn’t work. I can log in to the admin panel, add domains and mailboxes, but I can’t connect to them with any external mail program.
root@s /home/#mail#/mailcow-dockerized # docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
aaa8b6f72ed0 robbertkl/ipv6nat “/docker-ipv6nat-com…” 11 minutes ago Up 10 minutes mailcowdockerized-ipv6nat-mailcow-1
f24eff8cfa47 ghcr.io/mailcow/watchdog:2.07 “/watchdog.sh” 11 minutes ago Up 10 minutes mailcowdockerized-watchdog-mailcow-1
a251d9511334 ghcr.io/mailcow/acme:1.92 “/sbin/tini -g – /s…” 11 minutes ago Up 10 minutes mailcowdockerized-acme-mailcow-1
93ad07f3bb0b ghcr.io/mailcow/nginx:1.03 “/docker-entrypoint.…” 11 minutes ago Up 10 minutes 0.0.0.0:8443->8443/tcp, [::]:8443->8443/tcp, 80/tcp, 0.0.0.0:8888->8888/tcp, [::]:8888->8888/tcp mailcowdockerized-nginx-mailcow-1
215a059beb7f ghcr.io/mailcow/rspamd:2.1 “/docker-entrypoint.…” 11 minutes ago Up 10 minutes mailcowdockerized-rspamd-mailcow-1
c29d3da83f7b mcuadros/ofelia:latest “/usr/bin/ofelia dae…” 11 minutes ago Up 11 minutes mailcowdockerized-ofelia-mailcow-1
527e4732d15a ghcr.io/mailcow/dovecot:2.33 “/docker-entrypoint.…” 11 minutes ago Up 11 minutes 0.0.0.0:110->110/tcp, [::]:110->110/tcp, 0.0.0.0:143->143/tcp, [::]:143->143/tcp, 0.0.0.0:993->993/tcp, [::]:993->993/tcp, 0.0.0.0:995->995/tcp, [::]:995->995/tcp, 0.0.0.0:4190->4190/tcp, [::]:4190->4190/tcp, 127.0.0.1:19991->12345/tcp mailcowdockerized-dovecot-mailcow-1
38924caa47b1 ghcr.io/mailcow/postfix:1.80 “/docker-entrypoint.…” 11 minutes ago Up 10 minutes 0.0.0.0:25->25/tcp, [::]:25->25/tcp, 0.0.0.0:465->465/tcp, [::]:465->465/tcp, 0.0.0.0:587->587/tcp, [::]:587->587/tcp, 588/tcp mailcowdockerized-postfix-mailcow-1
39aee44c5aa0 ghcr.io/mailcow/phpfpm:1.93 “/docker-entrypoint.…” 11 minutes ago Up 11 minutes 9000/tcp mailcowdockerized-php-fpm-mailcow-1
cf6858c2d021 mariadb:10.11 “docker-entrypoint.s…” 11 minutes ago Up 11 minutes 127.0.0.1:13306->3306/tcp mailcowdockerized-mysql-mailcow-1
fd3cf143df2b ghcr.io/mailcow/clamd:1.70 “/sbin/tini -g – /c…” 11 minutes ago Up 10 minutes (healthy) mailcowdockerized-clamd-mailcow-1
37f30325050a redis:7.4.2-alpine “/bin/sh /redis-conf…” 11 minutes ago Up 11 minutes 127.0.0.1:7654->6379/tcp mailcowdockerized-redis-mailcow-1
afdc783cdd40 memcached:alpine “docker-entrypoint.s…” 11 minutes ago Up 11 minutes 11211/tcp mailcowdockerized-memcached-mailcow-1
5bfe306dc436 ghcr.io/mailcow/dockerapi:2.11 “/bin/sh /app/docker…” 11 minutes ago Up 11 minutes mailcowdockerized-dockerapi-mailcow-1
6d7211a27f3e ghcr.io/mailcow/sogo:1.131 “/docker-entrypoint.…” 11 minutes ago Up 5 minutes mailcowdockerized-sogo-mailcow-1
2e52b0fda3f2 ghcr.io/mailcow/unbound:1.24 “/docker-entrypoint.…” 11 minutes ago Up 11 minutes (healthy) 53/tcp, 53/udp mailcowdockerized-unbound-mailcow-1
b8d493469613 ghcr.io/mailcow/netfilter:1.62 “/bin/sh -c /app/doc…” 11 minutes ago Up 8 seconds mailcowdockerized-netfilter-mailcow-1
7eafc9250886 ghcr.io/mailcow/olefy:1.14 “python3 -u /app/ole…” 11 minutes ago Up 11 minutes mailcowdockerized-olefy-mailcow-1
root@s /home/#mail#/mailcow-dockerized # C
root@s /home/#mail#/mailcow-dockerized # docker-compose logs mariadb-mailcow
root@s /home/#mail#/mailcow-dockerized # docker-compose logs dovecot-mailcow
dovecot-mailcow-1 | Waiting for database to come up…
dovecot-mailcow-1 | Uptime: 0 Threads: 2 Questions: 2 Slow queries: 0 Opens: 17 Open tables: 10 Queries per second avg: 0.000
dovecot-mailcow-1 | Detecting SKIP_FTS=n… enabling Flatcurve (FTS)
dovecot-mailcow-1 | Configuring FTS Settings…
dovecot-mailcow-1 | Setting FTS Memory Limit (per process) to 128 MB
dovecot-mailcow-1 | Setting FTS Process Limit to 1
dovecot-mailcow-1 | grep: /etc/dovecot/extra.conf: No such file or directory
dovecot-mailcow-1 | Waiting for versions table to be created…
dovecot-mailcow-1 | % Total % Received % Xferd Average Speed Time Time Time Current
dovecot-mailcow-1 | Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 –:–:– 0:00:15 –:–:– 0
dovecot-mailcow-1 | curl: (28) Connection timed out after 15002 milliseconds
dovecot-mailcow-1 | Warning: Problem : timeout. Will retry in 1 seconds. 5 retries left.
dovecot-mailcow-1 | Warning: Problem : timeout. Will retry in 2 seconds. 4 retries left.
dovecot-mailcow-1 | Warning: Problem : timeout. Will retry in 4 seconds. 3 retries left.
dovecot-mailcow-1 | curl: (28) Connection timed out after 15003 milliseconds
dovecot-mailcow-1 | Warning: Problem : timeout. Will retry in 8 seconds. 2 retries left.
dovecot-mailcow-1 | Warning: Problem : timeout. Will retry in 16 seconds. 1 retries left.
dovecot-mailcow-1 | Failed to download SA rules. Exiting.
dovecot-mailcow-1 | 2025-03-25 17:03:44,630 INFO Set uid to user 0 succeeded
dovecot-mailcow-1 | 2025-03-25 17:03:44,631 INFO supervisord started with pid 1
dovecot-mailcow-1 | 2025-03-25 17:03:45,635 INFO spawned: ‘processes’ with pid 181
dovecot-mailcow-1 | 2025-03-25 17:03:45,638 INFO spawned: ‘dovecot’ with pid 182
dovecot-mailcow-1 | 2025-03-25 17:03:45,641 INFO spawned: ‘syslog-ng’ with pid 183
dovecot-mailcow-1 | Mar 25 17:03:45 527e4732d15a syslog-ng[183]: syslog-ng starting up; version=‘4.8.1’
dovecot-mailcow-1 | Mar 25 17:03:45 527e4732d15a dovecot: master: Dovecot v2.3.21.1 (d492236fa0) starting up for imap, sieve, lmtp, pop3
dovecot-mailcow-1 | 2025-03-25 17:03:46,707 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
dovecot-mailcow-1 | 2025-03-25 17:03:46,707 INFO success: dovecot entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
dovecot-mailcow-1 | 2025-03-25 17:03:46,707 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
dovecot-mailcow-1 | Mar 25 17:03:46 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:03:46 527e4732d15a dovecot: auth-worker(201): conn unix:auth-worker (pid=200,uid=401): auth-worker<5>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:03:46 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:03:46 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:03:46 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:04:22 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:04:22 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:04:22 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:04:22 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:05:41 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:05:41 527e4732d15a dovecot: auth-worker(291): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:05:41 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:05:41 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:05:41 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:06:17 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:06:17 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:06:17 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:06:17 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:06:58 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:06:58 527e4732d15a dovecot: auth-worker(348): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:06:58 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:06:58 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:06:58 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:07:37 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:07:58 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:07:58 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:07:58 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:07:58 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:08:51 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:08:51 527e4732d15a dovecot: auth-worker(427): conn unix:auth-worker (pid=200,uid=401): auth-worker<3>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:08:51 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:08:51 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:08:51 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:09:21 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:09:21 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:09:21 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:09:21 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:10:38 527e4732d15a dovecot: lmtp(203): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:10:38 527e4732d15a dovecot: auth-worker(508): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:10:38 527e4732d15a dovecot: lmtp(203): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:10:38 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:10:38 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:11:57 527e4732d15a dovecot: lmtp(559): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:11:57 527e4732d15a dovecot: auth-worker(561): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:11:57 527e4732d15a dovecot: lmtp(559): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:11:57 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:11:57 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:12:37 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:12:58 527e4732d15a dovecot: lmtp(559): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:12:58 527e4732d15a dovecot: auth-worker(602): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:12:58 527e4732d15a dovecot: lmtp(559): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:12:58 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:12:58 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:13:37 527e4732d15a dovecot: lmtp(559): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:13:37 527e4732d15a dovecot: lmtp(559): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:13:37 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:13:37 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:14:56 527e4732d15a dovecot: lmtp(681): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:14:56 527e4732d15a dovecot: auth-worker(683): conn unix:auth-worker (pid=200,uid=401): auth-worker<1>: sql(watchdog@invalid,172.22.1.12): unknown user
dovecot-mailcow-1 | Mar 25 17:14:56 527e4732d15a dovecot: lmtp(681): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:14:56 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:14:56 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
dovecot-mailcow-1 | Mar 25 17:15:20 527e4732d15a dovecot: lmtp(681): Connect from 172.22.1.12
dovecot-mailcow-1 | Mar 25 17:15:20 527e4732d15a dovecot: lmtp(681): Disconnect from 172.22.1.12: Logged out (state=MAIL FROM)
dovecot-mailcow-1 | Mar 25 17:15:20 527e4732d15a dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
dovecot-mailcow-1 | Mar 25 17:15:20 527e4732d15a dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.12, lip=172.22.1.250
root@s /home/#mail#/mailcow-dockerized # docker-compose logs mysql-mailcow
mysql-mailcow-1 | 2025-03-25 17:01:34+01:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.11.11+mariaubu2204 started.
mysql-mailcow-1 | 2025-03-25 17:01:34+01:00 [Warn] [Entrypoint]: /sys/fs/cgroup///memory.pressure not writable, functionality unavailable to MariaDB
mysql-mailcow-1 | 2025-03-25 17:01:34+01:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
mysql-mailcow-1 | 2025-03-25 17:01:34+01:00 [Note] [Entrypoint]: Initializing database files
mysql-mailcow-1 | 2025-03-25 17:01:35 0 [Warning] mariadbd: io_uring_queue_init() failed with errno 1
mysql-mailcow-1 | 2025-03-25 17:01:35 0 [Warning] InnoDB: liburing disabled: falling back to innodb_use_native_aio=OFF
mysql-mailcow-1 | 2025-03-25 17:01:36+01:00 [Note] [Entrypoint]: Database files initialized
mysql-mailcow-1 | 2025-03-25 17:01:36+01:00 [Note] [Entrypoint]: Starting temporary server
mysql-mailcow-1 | 2025-03-25 17:01:36+01:00 [Note] [Entrypoint]: Waiting for server startup
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] Starting MariaDB 10.11.11-MariaDB-ubu2204 source revision e69f8cae1a15e15b9e4f5e0f8497e1f17bdc81a4 server_uid wL7NaWn4/zDP/sLPWSc+4CuOMH8= as process 95
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Number of transaction pools: 1
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Warning] mariadbd: io_uring_queue_init() failed with errno 1
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Warning] InnoDB: liburing disabled: falling back to innodb_use_native_aio=OFF
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Initializing buffer pool, total size = 24.000MiB, chunk size = 1.000MiB
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Completed initialization of buffer pool
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: File system buffers for log disabled (block size=4096 bytes)
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: End of log at LSN=46996
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: 128 rollback segments are active.
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] InnoDB: log sequence number 46996; transaction id 14
mysql-mailcow-1 | 2025-03-25 17:01:37 1 [Note] Event Scheduler: scheduler thread started with id 1
mysql-mailcow-1 | 2025-03-25 17:01:37 0 [Note] mariadbd: ready for connections.
mysql-mailcow-1 | Version: ‘10.11.11-MariaDB-ubu2204’ socket: ‘/run/mysqld/mysqld.sock’ port: 0 mariadb.org binary distribution
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Temporary server started.
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Creating database mailcow
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Creating user mailcow
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Giving user mailcow access to schema mailcow
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Securing system users (equivalent to running mysql_secure_installation)
mysql-mailcow-1 |
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Stopping temporary server
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] mariadbd (initiated by: unknown): Normal shutdown
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Event Scheduler: Killing the scheduler thread, thread id 1
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Event Scheduler: Waiting for the scheduler thread to reply
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Event Scheduler: Stopped
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: FTS optimize thread exiting.
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Starting shutdown…
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Buffer pool(s) dump completed at 250325 17:01:38
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Shutdown completed; log sequence number 46996; transaction id 15
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] mariadbd: Shutdown complete
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: Temporary server stopped
mysql-mailcow-1 |
mysql-mailcow-1 | 2025-03-25 17:01:38+01:00 [Note] [Entrypoint]: MariaDB init process done. Ready for start up.
mysql-mailcow-1 |
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Starting MariaDB 10.11.11-MariaDB-ubu2204 source revision e69f8cae1a15e15b9e4f5e0f8497e1f17bdc81a4 server_uid wL7NaWn4/zDP/sLPWSc+4CuOMH8= as process 1
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Number of transaction pools: 1
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Warning] mariadbd: io_uring_queue_init() failed with errno 1
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Warning] InnoDB: liburing disabled: falling back to innodb_use_native_aio=OFF
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Initializing buffer pool, total size = 24.000MiB, chunk size = 1.000MiB
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Completed initialization of buffer pool
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: File system buffers for log disabled (block size=4096 bytes)
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: End of log at LSN=46996
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: 128 rollback segments are active.
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12.000MiB. Physically writing the file full; Please wait …
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12.000MiB.
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: log sequence number 46996; transaction id 14
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] InnoDB: Buffer pool(s) load completed at 250325 17:01:38
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Warning] You need to use –log-bin to make –expire-logs-days or –binlog-expire-logs-seconds work.
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Server socket created on IP: ‘0.0.0.0’.
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] Server socket created on IP: ‘::’.
mysql-mailcow-1 | 2025-03-25 17:01:38 1 [Note] Event Scheduler: scheduler thread started with id 1
mysql-mailcow-1 | 2025-03-25 17:01:38 0 [Note] mariadbd: ready for connections.
mysql-mailcow-1 | Version: ‘10.11.11-MariaDB-ubu2204’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
