Been looking into running my email server in my house as it has much stronger hardware
i am at a loss as to what to do to forward the connection to a relay/proxy like service on a VPS
note: this is more than just a smtp relay i have that working already, i need proxy for imap/pop (viewing email) and smtp(receiving email)
i am looking at https://docs.nginx.com/nginx/admin-guide/mail-proxy/mail-proxy/
the idea is with nginx and the mail modules
- a client connects to nginx on the vps.
- nginx gets the user, password, and, port and converts them to headers
- passes that to the auth_http  directive which points to a web destination
- that web destination takes the user, password, port and checks if they are valid (like it is an active user on the server) and returns info to be use as a reverse proxy
what config should i make to have this work?
The reason i want this setup is:
- a more static ip on a server in a datacenter
- spending less money as the vps does not need to be as powerful
- minimize my emails going through a large comapny’s server
- more control over my email
- bypass isp port 25 blocking
