I installed a brand new MailCow. I have followed all the steps described here: https://docs.mailcow.email/
I’ve set up a domain inside the server, created a mailbox, and configured all the DNS settings accordingly. In the test, I can send and receive emails normally through sogo, but when I use the client software, I can’t connect to the mailbox, I can’t find any workaround in the documentation…
Using client software during testing, these Dovecot log outputs were discovered
The client software used is Thunderbird
Feb 11 12:59:15 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 12:59:15 6b121d085101 dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 13:00:05 6b121d085101 dovecot: lmtp(5704): Connect from 172.22.1.11
Feb 11 13:00:05 6b121d085101 dovecot: lmtp(5704): Disconnect from 172.22.1.11: Logged out (state=MAIL FROM)
Feb 11 13:00:05 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
Feb 11 13:00:05 6b121d085101 dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 13:01:15 6b121d085101 dovecot: lmtp(5778): Connect from 172.22.1.11
Feb 11 13:01:15 6b121d085101 dovecot: lmtp(5778): Disconnect from 172.22.1.11: Logged out (state=MAIL FROM)
Feb 11 13:01:15 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
Feb 11 13:01:15 6b121d085101 dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 13:01:42 6b121d085101 dovecot: lmtp(5778): Connect from 172.22.1.11
Feb 11 13:01:42 6b121d085101 dovecot: lmtp(5778): Disconnect from 172.22.1.11: Logged out (state=MAIL FROM)
Feb 11 13:01:42 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
Feb 11 13:01:42 6b121d085101 dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 13:02:29 6b121d085101 dovecot: lmtp(5778): Connect from 172.22.1.11
Feb 11 13:02:29 6b121d085101 dovecot: lmtp(5778): Disconnect from 172.22.1.11: Logged out (state=MAIL FROM)
Feb 11 13:02:29 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
Feb 11 13:02:29 6b121d085101 dovecot: managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250
Feb 11 13:03:25 6b121d085101 dovecot: lmtp(5778): Connect from 172.22.1.11
Feb 11 13:03:25 6b121d085101 dovecot: lmtp(5778): Disconnect from 172.22.1.11: Logged out (state=MAIL FROM)
Feb 11 13:03:25 6b121d085101 dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.22.1.11, lip=172.22.1.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
