I am strugling to connect on IMAP on port 993. I get a certificate expired error, but when I access via the API it works perfectly and even checking the certificate manually on the URL works fine. Is there another place I need to setup the certificate for IMAP specifically? Seems weird right?
Thank you in advance
  • esackbauer
    Moolevel 379
Let me guess, you have a reverse proxy in front of mailcow
We are running Traefik, thanks for the headsup. Will dive into it and get back with the results
