Hey Folks,
unfortunately, I’ve had a problem since the last update. I can no longer log in with Webauthn, nor can I use Webauthn as a second factor. Even though I haven’t changed anything in the configuration, it sounds like a config problem to me. This is the error message:
Maybe someone has had the same problem or can point me in the right direction. Thanks in advance!
Best Jani
