I have my email server with MailCow. It is set on VPS.
This server serves several of my domains and several email accounts.
A few days ago my SSL certificate expired. I was convinced that MailCow would renew it automatically, but it didn’t.
I wanted to do it manually, but I have a lot of errors that I don’t really know how to deal with. The log is under the post.
Currently, I do not have access to emails because after entering the address in the browser I receive the error:
You cannot visit mail.myserverdomain.co.uk right now because the website uses HSTS. Network errors and attacks are usually temporary, so this page will probably work later.
The latest version of MailCow. I did an update on April 19th
Log from SSL certificate renewal:
root@mail:/opt/mailcow-dockerized# docker-compose restart acme-mailcow && docker-compose logs -f --tail=100 acme-mailcow
[+] Restarting 1/1
✔ Container mailcowdockerized-acme-mailcow-1 Started 0.5s
acme-mailcow-1 | Sun May 12 09:36:28 BST 2024 - Certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem is due for renewal (< 30 days) - start renewing
acme-mailcow-1 | Sun May 12 09:36:28 BST 2024 - Creating backups in /var/lib/acme/backups/mail.myserverdomain.co.uk/2024-05-12_09_36_28 ...
acme-mailcow-1 | Sun May 12 09:36:28 BST 2024 - Checking resolver...
acme-mailcow-1 | Sun May 12 09:36:28 BST 2024 - Resolver OK
acme-mailcow-1 | Sun May 12 09:36:28 BST 2024 - Using command acme-tiny --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/mail.myserverdomain.co.uk/acme.csr --acme-dir /var/www/acme/
acme-mailcow-1 | Parsing account key...
acme-mailcow-1 | Parsing CSR...
acme-mailcow-1 | Found domains: mail.myserverdomain.co.uk
acme-mailcow-1 | Getting directory...
acme-mailcow-1 | Directory found!
acme-mailcow-1 | Registering account...
acme-mailcow-1 | Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/1xxxx10026
acme-mailcow-1 | Creating new order...
acme-mailcow-1 | Order created!
acme-mailcow-1 | Verifying mail.myserverdomain.co.uk...
acme-mailcow-1 | Traceback (most recent call last):
acme-mailcow-1 | File "/usr/bin/acme-tiny", line 8, in <module>
acme-mailcow-1 | sys.exit(main())
acme-mailcow-1 | ^^^^^^
acme-mailcow-1 | File "/usr/lib/python3.11/site-packages/acme_tiny.py", line 195, in main
acme-mailcow-1 | signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact, check_port=args.check_port)
acme-mailcow-1 | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
acme-mailcow-1 | File "/usr/lib/python3.11/site-packages/acme_tiny.py", line 153, in get_crt
acme-mailcow-1 | raise ValueError("Challenge did not pass for {0}: {1}".format(domain, authorization))
acme-mailcow-1 | ValueError: Challenge did not pass for mail.myserverdomain.co.uk: {'identifier': {'type': 'dns', 'value': 'mail.myserverdomain.co.uk'}, 'status': 'invalid', 'expires': '2024-05-19T08:36:32Z', 'challenges': [{'type': 'http-01', 'status': 'invalid', 'error': {'type': 'urn:ietf:params:acme:error:connection', 'detail': '5.xxx.xxx.12: Fetching http://mail.myserverdomain.co.uk/.well-known/acme-challenge/0JwQCRe6sq6WxxxxcwXsR35xxxConwUxxxrd6v-Bkpu0s: Timeout during connect (likely firewall problem)', 'status': 400}, 'url': 'https://acme-v02.api.letsencrypt.org/acme/chall-v3/34xxxxx525527/QoBS1A', 'token': '0JwQCRe6sq6WxxxxxxxxxxXsR35pteConwURrd6v-Bkpu0s', 'validationRecord': [{'url': 'http://mail.myserverdomain.co.uk/.well-known/acme-challenge/0JxxxxxxtHcwXsR35pteConwURrd6v-Bkpu0s', 'hostname': 'mail.myserverdomain.co.uk', 'port': '80', 'addressesResolved': ['5.xxx.xxx.12'], 'addressUsed': '5.xxx.xxx.12'}], 'validated': '2024-05-12T08:36:34Z'}]}
acme-mailcow-1 | Sun May 12 09:36:46 BST 2024 - Failed to obtain certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem for domains 'mail.myserverdomain.co.uk'
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 09:36:46 BST 2024 - Some errors occurred, retrying in 30 minutes...
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for Docker API...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Docker API OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for Postfix...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Postfix OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for Dovecot...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Dovecot OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for database...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Database OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for Nginx...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Nginx OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for resolver...
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Resolver OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Waiting for domain table...
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:06:46 BST 2024 - Initializing, please wait...
acme-mailcow-1 | Sun May 12 10:06:47 BST 2024 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow-1 | Sun May 12 10:06:47 BST 2024 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow-1 | Sun May 12 10:06:47 BST 2024 - Detecting IP addresses...
acme-mailcow-1 | Sun May 12 10:07:06 BST 2024 - OK: 5.xxx.xxx.12, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow-1 | Sun May 12 10:07:13 BST 2024 - No A or AAAA record found for hostname autodiscover.domain1.pl
acme-mailcow-1 | Sun May 12 10:07:13 BST 2024 - No A or AAAA record found for hostname autoconfig.domain1.pl
acme-mailcow-1 | Sun May 12 10:07:18 BST 2024 - No A or AAAA record found for hostname autodiscover.myserverdomain.co.uk
acme-mailcow-1 | Sun May 12 10:07:18 BST 2024 - No A or AAAA record found for hostname autoconfig.myserverdomain.co.uk
acme-mailcow-1 | Sun May 12 10:07:21 BST 2024 - No A or AAAA record found for hostname autodiscover.domain2.co.uk
acme-mailcow-1 | Sun May 12 10:07:21 BST 2024 - No A or AAAA record found for hostname autoconfig.domain2.co.uk
acme-mailcow-1 | Sun May 12 10:07:22 BST 2024 - No A or AAAA record found for hostname autodiscover.domain3.co.uk
acme-mailcow-1 | Sun May 12 10:07:24 BST 2024 - No A or AAAA record found for hostname autoconfig.domain3.co.uk
acme-mailcow-1 | Sun May 12 10:07:25 BST 2024 - No A or AAAA record found for hostname autodiscover.domain4.co.uk
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - No A or AAAA record found for hostname autoconfig.domain4.co.uk
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - Found A record for mail.myserverdomain.co.uk: 5.xxx.xxx.12
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - Confirmed A record 5.xxx.xxx.12
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - Certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem is due for renewal (< 30 days) - start renewing
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - Creating backups in /var/lib/acme/backups/mail.myserverdomain.co.uk/2024-05-12_10_07_26 ...
acme-mailcow-1 | Sun May 12 10:07:26 BST 2024 - Checking resolver...
acme-mailcow-1 | Sun May 12 10:07:27 BST 2024 - Resolver OK
acme-mailcow-1 | Sun May 12 10:07:27 BST 2024 - Using command acme-tiny --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/mail.myserverdomain.co.uk/acme.csr --acme-dir /var/www/acme/
acme-mailcow-1 | Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/1xxxxx0026
acme-mailcow-1 | ValueError: Challenge did not pass for mail.myserverdomain.co.uk: {'identifier': {'type': 'dns', 'value': 'mail.myserverdomain.co.uk'}, 'status': 'invalid', 'expires': '2024-05-19T09:07:30Z', 'challenges': [{'type': 'http-01', 'status': 'invalid', 'error': {'type': 'urn:ietf:params:acme:error:connection', 'detail': '5.xxx.xxx.12: Fetching http://mail.myserverdomain.co.uk/.well-known/acme-challenge/6GUExxxxxxxsxxxq-PWI2xxxxxxxxr92ZEFLrScTq-mQ: Timeout during connect (likely firewall problem)', 'status': 400}, 'url': 'https://acme-v02.api.letsencrypt.org/acme/chall-v3/349xxxxxxx897/hpd0rg', 'token': '6GUxxxxxxPdsq-PWI2dxxxxxxxxxxFLrScTq-mQ', 'validationRecord': [{'url': 'http://mail.myserverdomain.co.uk/.well-known/acme-challenge/6GUExxxxxxxxxxq-PWI2xxxxxxxxxxxxx2ZEFLrScTq-mQ', 'hostname': 'mail.myserverdomain.co.uk', 'port': '80', 'addressesResolved': ['5.xxx.xxx.12'], 'addressUsed': '5.xxx.xxx.12'}], 'validated': '2024-05-12T09:07:32Z'}]}
acme-mailcow-1 | Sun May 12 10:07:45 BST 2024 - Failed to obtain certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem for domains 'mail.myserverdomain.co.uk'
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:07:45 BST 2024 - Some errors occurred, retrying in 30 minutes...
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for Docker API...
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Docker API OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for Postfix...
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Postfix OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for Dovecot...
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Dovecot OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for database...
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Database OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for Nginx...
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Nginx OK
acme-mailcow-1 | Sun May 12 10:31:52 BST 2024 - Waiting for resolver...
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Resolver OK
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Waiting for domain table...
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Initializing, please wait...
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow-1 | Sun May 12 10:31:54 BST 2024 - Detecting IP addresses...
acme-mailcow-1 | Sun May 12 10:32:17 BST 2024 - OK: 5.xxx.xxx.12, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow-1 | Sun May 12 10:32:19 BST 2024 - No A or AAAA record found for hostname autodiscover.domain1.pl
acme-mailcow-1 | Sun May 12 10:32:21 BST 2024 - No A or AAAA record found for hostname autoconfig.domain1.pl
acme-mailcow-1 | Sun May 12 10:32:23 BST 2024 - No A or AAAA record found for hostname autodiscover.myserverdomain.co.uk
acme-mailcow-1 | Sun May 12 10:32:24 BST 2024 - No A or AAAA record found for hostname autoconfig.myserverdomain.co.uk
acme-mailcow-1 | Sun May 12 10:32:27 BST 2024 - No A or AAAA record found for hostname autodiscover.domain2.co.uk
acme-mailcow-1 | Sun May 12 10:32:28 BST 2024 - No A or AAAA record found for hostname autoconfig.domain2.co.uk
acme-mailcow-1 | Sun May 12 10:32:28 BST 2024 - No A or AAAA record found for hostname autodiscover.domain3.co.uk
acme-mailcow-1 | Sun May 12 10:32:29 BST 2024 - No A or AAAA record found for hostname autoconfig.domain3.co.uk
acme-mailcow-1 | Sun May 12 10:32:32 BST 2024 - No A or AAAA record found for hostname autodiscover.domain4.co.uk
acme-mailcow-1 | Sun May 12 10:32:33 BST 2024 - No A or AAAA record found for hostname autoconfig.domain4.co.uk
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Found A record for mail.myserverdomain.co.uk: 5.xxx.xxx.12
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Confirmed A record 5.xxx.xxx.12
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem is due for renewal (< 30 days) - start renewing
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Creating backups in /var/lib/acme/backups/mail.myserverdomain.co.uk/2024-05-12_10_32_34 ...
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Checking resolver...
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Resolver OK
acme-mailcow-1 | Sun May 12 10:32:34 BST 2024 - Using command acme-tiny --account-key /var/lib/acme/acme/account.pem --disable-check --csr /var/lib/acme/mail.myserverdomain.co.uk/acme.csr --acme-dir /var/www/acme/
acme-mailcow-1 | Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/15xxxxxx026
acme-mailcow-1 | ValueError: Challenge did not pass for mail.myserverdomain.co.uk: {'identifier': {'type': 'dns', 'value': 'mail.myserverdomain.co.uk'}, 'status': 'invalid', 'expires': '2024-05-19T09:32:37Z', 'challenges': [{'type': 'http-01', 'status': 'invalid', 'error': {'type': 'urn:ietf:params:acme:error:connection', 'detail': '5.xxx.xxx.12: Fetching http://mail.myserverdomain.co.uk/.well-known/acme-challenge/Dy2gDNpwQUMxxxxxxxxcvAfgqnxad2RUSO3fM: Timeout during connect (likely firewall problem)', 'status': 400}, 'url': 'https://acme-v02.api.letsencrypt.org/acme/chall-v3/3xxxxxxxx17/CKuexx', 'token': 'Dy2gDNpwxxxxxxx81toCcvAfgqxxxxxxxxO3fM', 'validationRecord': [{'url': 'http://mail.myserverdomain.co.uk/.well-known/acme-challenge/Dyxxxxxxxxxxxxxxxxxxx81toCcvAfgqnxadxxUSO3fM', 'hostname': 'mail.myserverdomain.co.uk', 'port': '80', 'addressesResolved': ['5.xxx.xxx.12'], 'addressUsed': '5.xxx.xxx.12'}], 'validated': '2024-05-12T09:32:39Z'}]}
acme-mailcow-1 | Sun May 12 10:32:51 BST 2024 - Failed to obtain certificate /var/lib/acme/mail.myserverdomain.co.uk/cert.pem for domains 'mail.myserverdomain.co.uk'
acme-mailcow-1 | OK
acme-mailcow-1 | Sun May 12 10:32:51 BST 2024 - Some errors occurred, retrying in 30 minutes...
acme-mailcow-1 | OK
Do you know how to resvole this issue?
