Hi all, I have just installed Mailcow on a new Server. After start up lets encrypt does not create Certificates. In the logs of the ACME-Mailcow I get the following log messages:
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for Docker API...
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Docker API OK
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for Postfix...
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Postfix OK
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for Dovecot...
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Dovecot OK
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for database...
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Database OK
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for Nginx...
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Nginx OK
acme-mailcow-1 | Mon Feb 19 14:20:51 CET 2024 - Waiting for resolver...
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Resolver OK
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Waiting for domain table...
acme-mailcow-1 | OK
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Initializing, please wait...
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow-1 | Mon Feb 19 14:20:52 CET 2024 - Detecting IP addresses...
acme-mailcow-1 | Mon Feb 19 14:21:13 CET 2024 - OK: <my_correct_ipv4>, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow-1 | Mon Feb 19 14:21:13 CET 2024 - Found AAAA record for autodiscover.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:21:13 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autodiscover.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:21:13 CET 2024 - Found AAAA record for autoconfig.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:21:13 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autoconfig.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:21:14 CET 2024 - Found AAAA record for mail.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:21:14 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mail.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:21:14 CET 2024 - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
acme-mailcow-1 | Mon Feb 19 14:21:14 CET 2024 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow-1 | OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for Docker API...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Docker API OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for Postfix...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Postfix OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for Dovecot...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Dovecot OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for database...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Database OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for Nginx...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Nginx OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for resolver...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Resolver OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Waiting for domain table...
acme-mailcow-1 | OK
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Initializing, please wait...
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow-1 | Mon Feb 19 14:26:20 CET 2024 - Detecting IP addresses...
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - OK: <my_correct_ipv4>, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Found AAAA record for autodiscover.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autodiscover.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Found AAAA record for autoconfig.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autoconfig.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Found AAAA record for mail.<domain>.com: <my_correct_ipv6> - skipping A record check
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mail.<domain>.com (DNS returned <my_correct_ipv6>)
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
acme-mailcow-1 | Mon Feb 19 14:26:40 CET 2024 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow-1 | OK
Also there is no folder /var/lib/acme/ on my server.
I have searched for quite some time now, but I have no idea what to do here.
I would say, that my DNS-Records are correctly set. The IPv6 can be found via the DNS, and it is the own IP address that seems to have problems.
Some ideas?
Thank you!
  • Looks about right… try:
    systemctl restart networking
    and check the status afterwards:
    journalctl -u networking
    If that doesn’t help and you still can’t see the IPv6 address, maybe reboot your server
    Edit: You said it’s a server from Contabo, check this (in German):
    https://contabo.com/blog/de/ipv6-auf-ihrem-server-einrichten/
    It’s old, but it says to run
    sudo enable_ipv6
    Give it a try
The ACME container isn’t able to determine your host’s IPv6 address. It uses this curl command to do it:
curl –connect-timeout 3 -m 10 -L6s ip6.mailcow.email
You can try to run this command on your host and inside the ACME container, Have a look at the output. Both on my host and in my container my IPv6 address is returned.
If it doesn’t work in your case, check your IPv6 config
Thank you for the fast reply.
I have tried it, and there is no output. I have checked, as good as i can, if the ip-config is wrong or anything. I don’t see the problem.
So reinstalled the server, and reinstalled mailcow again. But unfortunately I have the exact same behaviour.
Where do I need to look, to check my IPv6 configuration? It looks like that is the problem.
You can check your local IPv6 with the ‘ip’ command. In my case my primary interface is eth0:
ip a s eth0
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether AF:FE:E5:E1:1b:cc brd ff:ff:ff:ff:ff:ff
    altname enp0s3
    inet 49.123.123.123/32 scope global dynamic noprefixroute eth0
       valid_lft 70225sec preferred_lft 70225sec
    inet6 abcd:efa:c012:2c4f::1/64 scope global noprefixroute
       valid_lft forever preferred_lft forever
    inet6 abcd::efab:1ff:fe3c:1bcc/64 scope link noprefixroute
Check for the ‘global’ scope inet6 address
Where are you hosting your mailcow?
Ok, so there is no inet 6 address:
ip a s eth0
link/ether 00:50:56:4e:c8:d3 brd ff:ff:ff:ff:ff:ff
altname enp0s18
altname ens18
inet <my_ip4_address>.65/24 brd <my_ip4_address>.255 scope global eth0
I have a Server from Contabo with Debian 12.
In my etc/network/interfaces file, there is ipv6 configured.
OK, so check the other interfaces on your server
ip a s
Check if you can see your IPv6 address on another interface
I have a br-mailcow with an inet6 entry. But this is not my configured IPv6 in the DNS:
br-mailcow: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:94:93:f1:d9 brd ff:ff:ff:ff:ff:ff
inet 172.22.1.1/24 brd 172.22.1.255 scope global br-mailcow
inet6 fd4d:6169:6c63:6f77::1/64 scope global
inet6 fe80::42:94ff:fe93:f1d9/64 scope link
inet6 fe80::1/64 scope link
Other than that, I see no IPv6 addresses.
I also have the lo one. I don’t know if this helps:
lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
    Mailcow_starter that’s the Docker bridge interface. So maybe check your interfaces file for syntax errors?
    `# The loopback network interface
    auto lo
    iface lo inet loopback
    “Hashtag” The primary network interface
    auto eth0
    iface eth0 inet static
    address <my_ip4>.65
    netmask 255.255.255.0
    gateway <my_ip4>.1
    dns-search invalid
    dns-nameservers 213.136.95.10 213.136.95.11
    up ip route replace <my_ip4>.0/24 via <gateway> dev eth0
    iface eth0 inet6 static
    address <my_ip6>
    netmask 64
    gateway fe80::1
    accept_ra 0
    autoconf 0
    privext 0
    I didn’t change much here, after the clean system-install.
    Thanks for staying with me here.
    Blog Icon IPv6 auf Ihrem Server einrichten
    sudo enable_ipv6
    Give it a try
    enable_ipv6 did the job!
    Thank you so much!
    Now I can tackle the next problems!
