Hello everyone, (my first post here, so please bear with me if I make any mistake),
I have been using mailcow for 3 months and stress testing it. So far, amazing.
I used update.sh yesterday afternoon, so all components are upto day. I’m not using SOLR or IPV6.
So now before I move my mailboxes over, I was using iMapSync. Couple of questions:
  1. Where are the actual log files for iMapSync? In the WebU, the log files don’t appear until much much later, after the sync job is complete. I would like to see what is happening while happening. I checked all the docker running services logs by using the docker-compose logs command, but nothing seems to contain the logs for iMapSync.
  2. Is there a way to get the iMapSync to run immediatley? It seems to wait for quite a while.
  3. And, I noticed (or it seemed like this to me), that if I put five iMapSync schedules, they don’t seem to run in parallel. It goes down the list. If that’s default behaviour, is there a way to change that?
Thank you for everyone’s help in advance.
2 months later
This question is quite old, but maybe I’m able to answer at least the first question, because I had the same one 🙂
It looks like imapsync is called from GitHub Icon imapsync_cron.pl
and the output is stored to the $stdout variable whose content is written to the database after the program is closed.
So IMHO you will not be able to access the output - except maybe via strace, which is not available in the container and has to be installed first.
Update: Ok, you will be at least able to strace it from the root OS:
strace -s 10000 -p <PID of imapsync_cron.pl>
Important: Use the PID of imapsync_cron.pl, not imapsync itself.
2 years later
Again, this question is quite old, but I find that running cat /proc/$(pgrep perl)/fd/1 connects you to the stdout of the perl script that runs imapsync, so you can see what it’s doing.
Helped me discover that imapsync was trying to sync [Gmail]/All Mail/!
