Hello,
I know there is a procedure to block reception to some boxes:
I want to make it so that only the user max@company.com is able to send mail to the distribution list all@company.com.
so if mails are sent to all@company.com, either from internal or external users other than the above user, the message should be blocked and Undelivered Mail Returned to Sender
how can I do it?
thanks
