Hallo zusammen,
ich habe gestern meinen Mailserver auf die aktuelle Debian gehoben und dabei scheint wohl irgendwie der Wurm hineingekommen zu sein.
Docker startet die Kuh nicht mehr und ich bin jetzt doch etwas ratlos.
Hier mal die Ausgabe vom Update-Script:
Detecting if your IP is listed on Spamhaus Bad ASN List...
Check completed! Your IP is clean
Detecting which build your mailcow runs on...
You are receiving stable updates (master).
To change that run the update.sh Script one time with the --nightly parameter to switch to nightly builds.
Updated 0 paths from ebbae122
Native IPv6 implementation available.
This will enable experimental features in the Docker daemon and configure Docker to do the IPv6 NATing instead of ipv6nat-mailcow.
!!! This step is recommended !!!
mailcow will try to roll back the changes if starting Docker fails after modifying the daemon.json configuration file.
Should we try to enable the native IPv6 implementation in Docker now (recommended)? [y/N] y
Warning: You seem to have modified the /etc/docker/daemon.json configuration by yourself and not fully/correctly activated the native IPv6 NAT implementation.
You will need to merge your existing configuration manually or fix/delete the existing daemon.json configuration before trying the update process again.
Please merge the following content and restart the Docker daemon:
{"ipv6":true,"fixed-cidr-v6":"fd00:dead:beef:c0::/80","experimental":true,"ip6tables":true}
Validating docker-compose stack configuration...
Checking for conflicting bridges...
Saving diff to update_diffs/diff_before_update_2023-09-08-00-09-54...
Prefetching images...
1.17: Pulling from mailcow/unbound
Digest: sha256:e18456e3b91d542124229b6e089f02ea2c94a006c5d7eed9874d28a3577f6aa9
Status: Image is up to date for mailcow/unbound:1.17
docker.io/mailcow/unbound:1.17
10.5: Pulling from library/mariadb
Digest: sha256:e16184ec37826ccdc2ea104211196623177232bfb166f60048832ea5e75975f4
Status: Image is up to date for mariadb:10.5
docker.io/library/mariadb:10.5
7-alpine: Pulling from library/redis
Digest: sha256:ef3296cb1b3a7eb40f2a992a398777a1c0b5b21df44f1a5bef84067f772daf54
Status: Image is up to date for redis:7-alpine
docker.io/library/redis:7-alpine
1.61: Pulling from mailcow/clamd
Digest: sha256:215b554a25deaeec750a175e73fa4636ec52e77c000da29dde00953c31fd20f4
Status: Image is up to date for mailcow/clamd:1.61
docker.io/mailcow/clamd:1.61
1.92: Pulling from mailcow/rspamd
Digest: sha256:92e3274dbf02fdfc74c5b6209f4fc0c74f6fee04211b2fca53188c30ad846ded
Status: Image is up to date for mailcow/rspamd:1.92
docker.io/mailcow/rspamd:1.92
1.84: Pulling from mailcow/phpfpm
Digest: sha256:967163dd2815cb738f4676beaa02c55f2614f3c087456511aa4b234706598e07
Status: Image is up to date for mailcow/phpfpm:1.84
docker.io/mailcow/phpfpm:1.84
1.118: Pulling from mailcow/sogo
Digest: sha256:297fd2f6dbac34e5bcd3afc0e2c8919ceb967bfa56ba21d8d5c9b4d9fd08884d
Status: Image is up to date for mailcow/sogo:1.118
docker.io/mailcow/sogo:1.118
1.24: Pulling from mailcow/dovecot
Digest: sha256:9cca8bc552b02c06ac9d972d3683c3029ca4ddada884fefac12c93400fc77dce
Status: Image is up to date for mailcow/dovecot:1.24
docker.io/mailcow/dovecot:1.24
1.71: Pulling from mailcow/postfix
Digest: sha256:c6f883187f893cb9d98a253bb164698cf3aef8fd239cda50927081a1c24c6112
Status: Image is up to date for mailcow/postfix:1.71
docker.io/mailcow/postfix:1.71
alpine: Pulling from library/memcached
Digest: sha256:6849b4e9ffa403adcb394b5874c0a392c2727dd87d74999c4b300bdc1bd37f22
Status: Image is up to date for memcached:alpine
docker.io/library/memcached:alpine
mainline-alpine: Pulling from library/nginx
Digest: sha256:16164a43b5faec40adb521e98272edc528e74f31c1352719132b8f7e53418d70
Status: Image is up to date for nginx:mainline-alpine
docker.io/library/nginx:mainline-alpine
1.84: Pulling from mailcow/acme
Digest: sha256:75c7a4526fa81f50541debf78b288cf650d32cc41089c8c35b28c5379ff81e0d
Status: Image is up to date for mailcow/acme:1.84
docker.io/mailcow/acme:1.84
1.52: Pulling from mailcow/netfilter
Digest: sha256:2bb9ee45e6e95e86ddb290fa77117cc33b140f75d1cc37fa230108b75e714d33
Status: Image is up to date for mailcow/netfilter:1.52
docker.io/mailcow/netfilter:1.52
1.97: Pulling from mailcow/watchdog
Digest: sha256:3e766c2c2171eab9de924164f19dc077a8fa5c7190ac66b945a63b7e58e5b018
Status: Image is up to date for mailcow/watchdog:1.97
docker.io/mailcow/watchdog:1.97
2.05: Pulling from mailcow/dockerapi
Digest: sha256:3f638ff36987fc8831bc226cd32f6ca22497323eff8353564b09ce21997fe8b4
Status: Image is up to date for mailcow/dockerapi:2.05
docker.io/mailcow/dockerapi:2.05
1.8.1: Pulling from mailcow/solr
Digest: sha256:c36a3fda39d51016b3e59253fb4ceb497ab11ee4f62c8e6460f8a425137bb763
Status: Image is up to date for mailcow/solr:1.8.1
docker.io/mailcow/solr:1.8.1
1.11: Pulling from mailcow/olefy
Digest: sha256:006ca6ff012f393cee87facadb480278317a839c7546b2ba94b94afdbb1f3ff7
Status: Image is up to date for mailcow/olefy:1.11
docker.io/mailcow/olefy:1.11
latest: Pulling from mcuadros/ofelia
Digest: sha256:21082a58c3d0d5d5b8615ac7d1ac5d039074728735879c76baf876c4358cbc3e
Status: Image is up to date for mcuadros/ofelia:latest
docker.io/mcuadros/ofelia:latest
Using default tag: latest
latest: Pulling from robbertkl/ipv6nat
Digest: sha256:0cf4971efbe9df3c39f6b11666bece782891856598c6d3649e900afc88f76c00
Status: Image is up to date for robbertkl/ipv6nat:latest
docker.io/robbertkl/ipv6nat:latest
Stopping mailcow...
[+] Running 1/1
⠿ Network mailcowdockerized_mailcow-network Removed 0.3s
Checking for remaining containers...
Committing current status...
Fetching updated code from remote...
Merging local with remote code (recursive, strategy: "theirs", options: "patience"...
Already up to date.
Fetching new images, if any...
[+] Running 19/19
⠿ ipv6nat-mailcow Pulled 1.0s
⠿ netfilter-mailcow Pulled 1.0s
⠿ memcached-mailcow Pulled 1.0s
⠿ nginx-mailcow Pulled 1.0s
⠿ solr-mailcow Pulled 1.0s
⠿ acme-mailcow Pulled 1.0s
⠿ dovecot-mailcow Pulled 0.9s
⠿ dockerapi-mailcow Pulled 1.0s
⠿ ofelia-mailcow Pulled 1.0s
⠿ redis-mailcow Pulled 1.0s
⠿ unbound-mailcow Pulled 0.9s
⠿ olefy-mailcow Pulled 0.9s
⠿ sogo-mailcow Pulled 0.9s
⠿ rspamd-mailcow Pulled 1.0s
⠿ watchdog-mailcow Pulled 1.0s
⠿ clamd-mailcow Pulled 1.0s
⠿ postfix-mailcow Pulled 1.0s
⠿ php-fpm-mailcow Pulled 1.0s
⠿ mysql-mailcow Pulled 1.0s
Checking IPv6 settings...
Starting mailcow...
[+] Running 1/1
⠿ Network mailcowdockerized_mailcow-network Created 0.1s
⠋ Container mailcowdockerized-memcached-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-watchdog-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-unbound-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-redis-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-dockerapi-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-olefy-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-sogo-mailcow-1 Creating 0.0s
⠋ Container mailcowdockerized-solr-mailcow-1 Creating 0.0s
Error response from daemon: error creating overlay mount to /var/lib/docker/overlay2/370b4b3fbbaa7f9ab5d4f0f1498a6afb571e014f948110c75309fb3ab719a824/merged: invalid argument
Hier die Docker info:
Client: Docker Engine - Community
Version: 24.0.6
Context: default
Debug Mode: false
Plugins:
compose: Docker Compose (Docker Inc.)
Version: v2.21.0
Path: /usr/libexec/docker/cli-plugins/docker-compose
scan: Docker Scan (Docker Inc.)
Version: v0.23.0
Path: /usr/libexec/docker/cli-plugins/docker-scan
Server:
Containers: 0
Running: 0
Paused: 0
Stopped: 0
Images: 25
Server Version: 24.0.6
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Using metacopy: false
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: io.containerd.runc.v2 runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 8165feabfdfe38c65b599c4993d227328c231fca
runc version: v1.1.8-0-g82f18fe
init version: de40ad0
Security Options:
seccomp
Profile: builtin
selinux
cgroupns
Kernel Version: 6.1.0-11-amd64
Operating System: Debian GNU/Linux 12 (bookworm)
OSType: linux
Architecture: x86_64
CPUs: 12
Total Memory: 62.66GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
Ich hoffe jemand von euch kann mir hier den passenden Tip mitgeben
