Hello,
When I run the update.sh I get the following output. My server is on AWS.
Detecting if your IP is listed on Spamhaus Bad ASN List...
./update.sh: line 261: [: : integer expression expected
./update.sh: line 276: [: : integer expression expected
./update.sh: line 278: [: : integer expression expected
Check failed! Maybe a DNS or Network problem?
What do you think the issue would be?
Thanks!
