Hi all i have 2 vms both running Ubuntu 22.04 with mailcow-dockerized installed on both.
I have ssh keys all setup and working ( no password needed to log in )
i then tried to run create_cold_standby.sh
I have made sure that i have rsync installed on both (v3.2.7)
the script seems to time out at checking rsync version so i disabled the check in the script
i then got [ERR] - Could not prepare remote for mailcow base directory transfer
I am stuck and have to migrate our company emails ASAP as our ISP is stopping hosting( PIA)
My 2 servers are on different ranges but connected via a site to site vpn no firewals between
  • SOLVED
    Looks like it was the site-site vpn encapsulation that was messing up the ssh packets. did a direct and worked like a charm.
got a bit further now gets stuck creating remote mount points
but did 2 volumes then crashed out
What happens if you just ssh between the servers?
Have you tried to just rsync’ing random folder across manually?
Hi Lnxgeek,
That all seems to work fine .
I dont need a keyfile to log into the second from the master .
so kinda update
sort of worked but now getting this
Creating consistent backup of MariaDB volume…
Open source backup tool for InnoDB and XtraDB
Copyright © 2009-2015 Percona LLC and/or its affiliates.
Portions Copyright © 2000, 2011, MySQL AB & Innobase Oy. All Rights Reserved.
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation version 2
of the License.
Then fails
with the below at the end
[ERR] - Could not create MariaDB backup on source
SOLVED
