I guess you’re on Hetzner ARM64 with the latest nightly build?
I’ve had the same problem. It seems like the new LDAP/identity provider implementation broke something.
Since the person in charge is currently on holiday, the installation of the nightly builds is not recommended at the moment.
I’ve switched back to x86_64 with stabile release and solved all these problems.
