esackbauer Maago There is. The version number is the minimum TB version you can use it with. Download and install the latest connector (which is currently 78.0.1)
Maago hmm .. I installed the Connector in TB, but there is no possibility to create a connection nor I can see any integration of SOGo Connector.
Maago in my TB there is nothing else than the default integrated TB calendar .. I cannot connect to a remote calendar with SOGo connector. Also nothing has changed in my already configured CalDav/CardDav ..
esackbauer Of course not… It INTEGRATES into Lightning Calendar (as it is written in SOGo documentation…). And it uses its configuration data.
Maago ok, so there is nothing changed with or without SOGo connector. All dialogs are the same, all fields are the same, all isuues are the same.
esackbauer It seems to be a long standing issue with Thunderbirds Lightning Calendar: https://bugzilla.mozilla.org/show_bug.cgi?id=865726
esackbauer It seems you have multiple aliases defined for your mailbox. You could use a mailbox with just your main e-Mail address configured. And use an additional mailbox with all the aliases configured.
Maago Meanwhile I removed all aliases from SOGo and TB .. and still the issue occurs. I don’t know where this name come from into the organisator field. I assume there is something in SOGo database ..
Maago Yes. As I said at beginning, I removed TB installations completely and tested also in a new VM.
Maago it seems with latest TB version something was changed. By default there will be still wrong email address, but now I can change it and persisits after saving.
