Ja es erscheint nur eine leere Seite!
Hier die Logzeilen
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <dyatkr>; map; read_map_file: /etc/rspamd/local.d/maps.d/spf_dkim_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <dyatkr>; map; read_map_file: /var/lib/rspamd/spf_dkim_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <dyatkr>; map; rspamd_kv_list_fin: read hash of 237 elements from https://maps.rspamd.com/rspamd/spf_dkim_whitelist.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <84c5si>; map; read_map_file: /etc/rspamd/local.d/maps.d/spf_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <84c5si>; map; read_map_file: /var/lib/rspamd/spf_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <8m79ek>; map; read_map_file: /etc/rspamd/local.d/maps.d/dkim_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <8m79ek>; map; read_map_file: /var/lib/rspamd/dkim_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qamb1r>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst from /var/lib/rspamd/877aa38dd77ed707d20b2f77d46b905b69a6295a.map, 10817 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2021-12-30 08:00:04; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qamb1r>; map; read_map_file: /etc/rspamd/local.d/maps.d/dmarc_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qamb1r>; map; read_map_file: /var/lib/rspamd/dmarc_whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qamb1r>; map; rspamd_kv_list_fin: read hash of 783 elements from https://maps.rspamd.com/rspamd/dmarc_whitelist_new.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <oxhd99>; map; rspamd_map_read_http_cached_file: read cached data for http://nginx:8081/settings.php from /var/lib/rspamd/f0f1f1ff89a5a9c0c3050fcb9ad2426aeacf1fdf.map, 710 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-19 16:21:54; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <pcx68s>; lua; settings.lua:1108: loaded 3 elements of settings
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qbq3yk>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/surbl-whitelist.inc.zst from /var/lib/rspamd/8fe64ecd161a46f91a78ece93609cb863f9f42f2.map, 11647 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2018-07-28 11:40:47; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qbq3yk>; map; read_map_file: /etc/rspamd/local.d/maps.d/surbl-whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qbq3yk>; map; read_map_file: /var/lib/rspamd/surbl-whitelist.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <qbq3yk>; map; rspamd_kv_list_fin: read hash of 828 elements from https://maps.rspamd.com/rspamd/surbl-whitelist.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <1u5hdp>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/redirectors.inc.zst from /var/lib/rspamd/f3933e67d5f9574a9eaf78cd0a8e99140ecc502e.map, 10363 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-10 21:00:03; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <1u5hdp>; map; read_map_file: /etc/rspamd/local.d/maps.d/redirectors.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <1u5hdp>; map; read_map_file: /etc/rspamd/local.d/redirectors.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <1u5hdp>; map; rspamd_kv_list_fin: read hash of 1072 elements from https://maps.rspamd.com/rspamd/redirectors.inc.zst
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:10:36 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:10:42 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:11:23 +0000] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:11:23 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:11:40 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:11:58 +0000] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:11:58 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:12:16 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:12:47 +0000] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | fd4d:6169:6c63:6f77::12 - - [20/Jan/2023:13:12:47 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:13:03 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:13:25 +0000] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | fd4d:6169:6c63:6f77::12 - - [20/Jan/2023:13:13:25 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:13:51 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:14:13 +0000] “HEAD /forwardinghosts.php HTTP/1.1” 200 0 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | fd4d:6169:6c63:6f77::12 - - [20/Jan/2023:13:14:13 +0000] “GET /forwardinghosts.php HTTP/1.1” 200 27 “-” “rspamd-3.4”
mailcowdockerized-nginx-mailcow-1 | 172.22.1.13 - - [20/Jan/2023:13:14:22 +0000] “HEAD /settings.php HTTP/1.1” 304 0 “-” “rspamd-3.4”
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:09:03 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:09:03 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:09:02 +0000 “GET /debug.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:09:41 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:09:41 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:09:58 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:10:36 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:09:47.331Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (c2f353fc7484)] Finished in “326.838222ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:09:47.395Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (047ef2f905b7)] Finished in “390.984874ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:09:47.42Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (fbbd81ca2f44)] Finished in “413.792532ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:09:47.436Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (0e559a23f97c)] Finished in “430.664461ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.002Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (2065142f6cc2)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.005Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (2b8bcc22bf7d)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/sieve.creds exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.006Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (da566ac35b77)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.02Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (832c56bc1605)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool expire-sessions ${SOGO_EXPIRE_SESSION} exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.209Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (2065142f6cc2)] Finished in “207.801356ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.301Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (da566ac35b77)] Finished in “295.266259ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.328Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (2b8bcc22bf7d)] Finished in “322.596358ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:10:47.389Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (832c56bc1605)] Finished in “368.14106ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.046Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (cc4270733228)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool expire-sessions ${SOGO_EXPIRE_SESSION} exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.048Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (098a0751ba25)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/sieve.creds exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.052Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (ade596d44b61)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.06Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (f4cceffe699f)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.298Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (ade596d44b61)] Finished in “246.177522ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.341Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (f4cceffe699f)] Finished in “281.1431ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.38Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (cc4270733228)] Finished in “334.426177ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:11:47.45Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (098a0751ba25)] Finished in “402.40398ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.024Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (a92d24484301)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool expire-sessions ${SOGO_EXPIRE_SESSION} exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.028Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (bc17ede96852)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.03Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (ec8d3907b452)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.036Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (ea66ee8e8f5f)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/sieve.creds exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.249Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (ec8d3907b452)] Finished in “219.079497ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.318Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (bc17ede96852)] Finished in “289.71488ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.327Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (a92d24484301)] Finished in “302.703241ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:12:47.413Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (ea66ee8e8f5f)] Finished in “377.134819ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.024Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (f4aca90e7978)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.025Z common.go:125 ▶ NOTICE [Job “dovecot_repl_health” (2be7f11a40e1)] Started - /bin/bash -c “/usr/local/bin/gosu vmail /usr/local/bin/repl_health.sh”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.025Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (253af8826011)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.03Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (685a1682ae9e)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/sieve.creds exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.042Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (db4a73edad92)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool expire-sessions ${SOGO_EXPIRE_SESSION} exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.044Z common.go:125 ▶ NOTICE [Job “sogo_eautoreply” (4038cd3d1afd)] Started - /bin/bash -c “[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool update-autoreply -p /etc/sogo/sieve.creds || exit 0”
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.288Z common.go:125 ▶ NOTICE [Job “dovecot_repl_health” (2be7f11a40e1)] Finished in “262.988758ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.346Z common.go:125 ▶ NOTICE [Job “dovecot_imapsync_runner” (253af8826011)] Finished in “320.457258ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.364Z common.go:125 ▶ NOTICE [Job “sogo_ealarms” (685a1682ae9e)] Finished in “334.615422ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.423Z common.go:125 ▶ NOTICE [Job “dovecot_trim_logs” (f4aca90e7978)] Finished in “399.1139ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.425Z common.go:125 ▶ NOTICE [Job “sogo_sessions” (db4a73edad92)] Finished in “383.030082ms”, failed: false, skipped: false, error: none
mailcowdockerized-ofelia-mailcow-1 | 2023-01-20T13:13:47.517Z common.go:125 ▶ NOTICE [Job “sogo_eautoreply” (4038cd3d1afd)] Finished in “472.973342ms”, failed: false, skipped: false, error: none
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:10:36 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:10:42 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:11:23 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:11:23 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:11:40 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:11:58 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:11:58 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:12:16 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:12:47 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:12:47 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:13:03 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:13:25 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:13:25 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:13:51 +0000 “HEAD /settings.php” 304
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:14:13 +0000 “HEAD /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | 172.22.1.10 - 20/Jan/2023:13:14:13 +0000 “GET /forwardinghosts.php” 200
mailcowdockerized-php-fpm-mailcow-1 | fd4d:6169:6c63:6f77::d - 20/Jan/2023:13:14:22 +0000 “HEAD /settings.php” 304
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <yhcyzt>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/phishing_whitelist.inc.zst from /var/lib/rspamd/110ec84de81cc98813b71d34d42dedbc199bd687.map, 170 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2021-02-25 19:17:32; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <yhcyzt>; map; read_map_file: /etc/rspamd/local.d/maps.d/phishing_whitelist.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <yhcyzt>; map; read_map_file: /etc/rspamd/local.d/phishing_whitelist.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <yhcyzt>; map; rspamd_re_map_finalize: hyperscan read 3 cached regular expressions from https://maps.rspamd.com/rspamd/phishing_whitelist.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <yhcyzt>; map; rspamd_regexp_list_fin: read regexp list of 3 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <d1sp7e>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <d1sp7e>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <amrk5d>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <amrk5d>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <esqk4o>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <esqk4o>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <q37eyd>; map; rspamd_map_read_http_cached_file: read cached data for http://nullnull.org/bad-subject-regex.txt from /var/lib/rspamd/2e77040678592ae8395d66b7f2c7c532f8f30315.map, 26847 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-19 17:20:44; etag: “63c97bec-68df”
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <q37eyd>; map; rspamd_re_map_finalize: hyperscan read 431 cached regular expressions from http://nullnull.org/bad-subject-regex.txt
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <q37eyd>; map; rspamd_regexp_list_fin: read regexp list of 431 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4ar9sf>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4ar9sf>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7m3drg>; map; rspamd_map_read_http_cached_file: read cached data for https://urlhaus.abuse.ch/downloads/text_online/ from /var/lib/rspamd/7de5410c328c7272aba5ee8b4afa11cfb92ab008.map, 233140 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-19 17:36:05; etag: “38eb4-5f2a15e0cc0b6”
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7m3drg>; map; rspamd_kv_list_fin: read hash of 5497 elements from https://urlhaus.abuse.ch/downloads/text_online/
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <eo6s69>; map; read_map_file: /etc/rspamd/custom/chat_versions.map: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <b4if5y>; map; rspamd_kv_list_fin: read hash of 0 elements from /etc/rspamd/custom/bad_asn.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <c6onet>; map; rspamd_map_read_http_cached_file: read cached data for https://bazaar.abuse.ch/export/txt/md5/recent/ from /var/lib/rspamd/cc4381220e9e543aaba78fb827b20f77c6b96b96.map, 32089 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-19 17:38:12; etag: “7d59-5f2a148656a2a”
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <c6onet>; map; rspamd_kv_list_fin: read hash of 929 elements from https://bazaar.abuse.ch/export/txt/md5/recent/
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <uqg9tz>; map; rspamd_radix_fin: read radix trie of 0 elements: ents=0 dup=0 tbm=1 lc=0 mem=1k free=0 waste=0
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <mik73a>; map; rspamd_re_map_finalize: hyperscan read 16 cached regular expressions from /etc/rspamd/custom/bad_words_de.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <mik73a>; map; rspamd_regexp_list_fin: read regexp list of 16 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <tk6bew>; map; rspamd_map_helper_insert_re: duplicate re entry found for map /etc/rspamd/custom/bad_words.map: /\slottery\s/i (old value: ‘1’, new: ‘1’)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <tk6bew>; map; rspamd_re_map_finalize: hyperscan read 27 cached regular expressions from /etc/rspamd/custom/bad_words.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <tk6bew>; map; rspamd_regexp_list_fin: read regexp list of 27 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <b8xy7e>; map; rspamd_re_map_finalize: hyperscan read 65 cached regular expressions from /etc/rspamd/custom/fishy_tlds.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <b8xy7e>; map; rspamd_regexp_list_fin: read regexp list of 65 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <58bhba>; map; rspamd_radix_fin: read radix trie of 2 elements: ents=2 dup=0 tbm=1 lc=6 mem=1k free=0 waste=0
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <kdbnze>; map; rspamd_re_map_finalize: hyperscan read 19 cached regular expressions from /etc/rspamd/custom/bulk_header.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <kdbnze>; map; rspamd_regexp_list_fin: read regexp list of 19 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <xuqyqw>; map; rspamd_re_map_finalize: hyperscan read 2 cached regular expressions from /etc/rspamd/custom/bad_header.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <xuqyqw>; map; rspamd_regexp_list_fin: read regexp list of 2 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <k8f914>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/freemail/disposable.txt.zst from /var/lib/rspamd/ea942f35f2c82e84bdb7b8ceb34537f7dbe986eb.map, 5911 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2019-06-25 18:22:49; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <k8f914>; map; rspamd_kv_list_fin: read hash of 427 elements from https://maps.rspamd.com/freemail/disposable.txt.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <jnkfot>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <jnkfot>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <e99k7g>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <e99k7g>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <fdp86m>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/freemail/free.txt.zst from /var/lib/rspamd/65b4e39783c10c8ed89dbec4983259f22418f34d.map, 56252 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2019-06-23 10:51:51; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <fdp86m>; map; rspamd_kv_list_fin: read hash of 4005 elements from https://maps.rspamd.com/freemail/free.txt.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <z7d36p>; map; rspamd_re_map_finalize: regexp map is empty
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <z7d36p>; map; rspamd_regexp_list_fin: read regexp list of 0 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <o33omj>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/mime_types.inc.zst from /var/lib/rspamd/2e66b2415ec9b99aaa155761c211e51def12016e.map, 48318 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2022-08-08 12:00:03; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <o33omj>; map; read_map_file: /etc/rspamd/local.d/maps.d/mime_types.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <o33omj>; map; read_map_file: /var/lib/rspamd/mime_types.inc.local: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <o33omj>; map; rspamd_kv_list_fin: read hash of 1545 elements from https://maps.rspamd.com/rspamd/mime_types.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7n3qic>; map; rspamd_map_read_http_cached_file: read cached data for https://maps.rspamd.com/rspamd/mid.inc.zst from /var/lib/rspamd/cb5a8189726ac3a8880e1c44ed6220c6d794521b.map, 900 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2022-10-22 06:21:02; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7n3qic>; map; read_map_file: /etc/rspamd/local.d/maps.d/mid.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7n3qic>; map; read_map_file: /etc/rspamd/local.d/mid.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <7n3qic>; map; rspamd_kv_list_fin: read hash of 37 elements from https://maps.rspamd.com/rspamd/mid.inc.zst
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; read_map_static: static: read map data, 180 bytes
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 2 cached regular expressions from static
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 2 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; read_map_static: static: read map data, 2466 bytes
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 104 cached regular expressions from static
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 104 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; read_map_static: static: read map data, 452 bytes
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_re_map_finalize: hyperscan read 24 cached regular expressions from static
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_regexp_list_fin: read regexp list of 24 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; read_map_static: static: read map data, 47 bytes
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <ks7cha>; map; read_map_file: /etc/rspamd/local.d/greylist-whitelist-domains.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <ks7cha>; map; read_map_file: /etc/rspamd/local.d/maps.d/greylist-whitelist-domains.inc: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <rznbhc>; map; rspamd_map_read_http_cached_file: read cached data for http://nginx:8081/forwardinghosts.php from /var/lib/rspamd/e48ac0193da10600fac6a17bb7146ba2421fee67.map, 16 bytes; next check at: 2023-01-20 13:09:03; last modified on: 2023-01-19 17:38:41; etag: (NULL)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <rznbhc>; map; rspamd_radix_fin: read radix trie of 1 elements: ents=1 dup=0 tbm=0 lc=3 mem=1k free=0 waste=0
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <us4pbz>; map; read_map_file: /etc/rspamd/antivirus.wl: map file is not found; it will be read automatically if created
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <ne5d4e>; map; rspamd_radix_fin: read radix trie of 2 elements: ents=2 dup=0 tbm=1 lc=6 mem=1k free=0 waste=0
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; read_map_static: static: read map data, 10 bytes
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <4dego7>; map; rspamd_radix_fin: read radix trie of 1 elements: ents=1 dup=0 tbm=0 lc=3 mem=1k free=0 waste=0
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <xg9×9p>; map; rspamd_re_map_finalize: hyperscan read 6 cached regular expressions from /etc/rspamd/custom/monitoring_nolog.map
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <xg9×9p>; map; rspamd_regexp_list_fin: read regexp list of 6 elements
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: rspamd 3.4 is starting, build id: release
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: cpu features: avx2, avx, sse2, sse3, ssse3, sse4.1, sse4.2, rdrand
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: cryptobox configuration: curve25519(libsodium), chacha20(avx2), poly1305(libsodium), siphash(libsodium), blake2(libsodium), base64(avx2)
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: libottery prf: AES-128
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: skip writing pid in no-fork mode
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: event loop initialised with backend: epoll
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; rspamd_fork_worker: prepare to fork process fuzzy (0); listen on: *
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; rspamd_fork_worker: prepare to fork process rspamd_proxy (0); listen on: rspamd:9900
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #41(fuzzy) <2dd354>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #41(fuzzy) <2dd354>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #42(rspamd_proxy) <2dd354>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #42(rspamd_proxy) <2dd354>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; rspamd_fork_worker: prepare to fork process controller (0); listen on: /var/lib/rspamd/rspamd.sock mode=0666 owner=nobody
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; rspamd_fork_worker: prepare to fork process normal (0); listen on: *
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; rspamd_fork_worker: prepare to fork process hs_helper (0), no bind socket
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #44(normal) <2dd354>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #44(normal) <2dd354>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #43(controller) <2dd354>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #43(controller) <2dd354>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #1(main) <2dd354>; main; main: listening for control commands on /var/lib/rspamd/rspamd.sock
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #43(controller) <pcx68s>; controller; rspamd_controller_password_sane: your normal password is not encrypted, we strongly recommend to replace it with the encrypted one
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #43(controller) <pcx68s>; controller; rspamd_controller_password_sane: enable password is not set, so you should filter controller availability by using of firewall or secure_ip option
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #45(hs_helper) <2dd354>; main; rspamd_worker_set_limits: use system max file descriptors limit: 1024KiB cur and 1024KiB max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:09:03 #45(hs_helper) <2dd354>; main; rspamd_worker_set_limits: use system max core size limit: -1B cur and -1B max
mailcowdockerized-rspamd-mailcow-1 | 2023-01-20 13:10:34 #43(controller) <q37eyd>; map; http_map_error: error reading http://nullnull.org/bad-subject-regex.txt([2a01:4f9:c010:687d::1]:80): connection with http server terminated incorrectly: IO write error: Network is unreachable
