Hi all,
I have a issue with emails arriving to my mailbox. They are all marked as read after a couple of minutes.
What could be the problem of this?
5 days later
23 days later
heavygale
If i disable pop3 for the user the it wont use pop3 anyway. am i wright?
heavygale
8 days later
heavygale
it only seems to happen to one account. i allredeay delete the account and recreated and restore the mails agenda and contacts.
still the same issue with this one account? how can we troubleshoot this?
Nobody?
it takes exactly 5 minutes before mail becomes read?
even when i delete this account and recreate it with the same name and dont restore anything i have the same problem.
other accounts dont i dont understand. how can i fully delete an account. no restovers in mailcow
6 days later
Change the password, so that no client can connect to this mailbox, then check in SoGO if the mails still get marked as read. (I still believe it’s a client, which marks the mails as read.)
    heavygale
    I forgot to reply. Allredeay dit That and it was a progam that i installed that was polling the inbox.
    Issue is revolved.
    a year later
    heavygale Thanks so much! Problem solved. This was the case with my issue.
    To solve it I created an extra file as described here docs.mailcow.email Icon Customize/Expand dovecot.conf - mailcow: dockerized documentation
    called extra.conf and added
    pop3_no_flag_updates=yes as described in your link Dovecot as a POP3 server — Dovecot documentation
    doc.dovecot.org
    LogoCreative Commons License
    , then
    docker compose restart dovecot-mailcow
    and now the issue is solved
