Hi!
I cannot find on Google propper instruction for install PHPMyAdmin to manage MailCow database.
Could You help me with short instruction ??
Regards
What do you want to manage / do with the database ? you can ssh into the container en login command-line with the credentials found in your mailcow config file if needed.
I need transport database data from PostfixAdmin to MailCow - the best way for me is a web interface to database.
Account data like e-mail address, password, alias.
Of course I look for install PHPMyAdmin in the same cointainer as MailCow.
Not sure if that is the best approach to get your addresses and aliases in there.. But if you setup a install a phpmyadmin on the host i think it can connect.. i can connect from my localhost to the ip of the container on 3306 so you should be able to, or setup separate container with phpmyadmin .. But i would strongly suggest to keep this tool offline after you are done to minimize potential security issues..
  • jata replied to this.
    mayk But i would strongly suggest to keep this tool offline after you are done to minimize potential security issues..
    It’s obvious!
    Ok, I will try install PHPMyAdmin as separate docker.
