Hey, I transferred mailboxes from another mail server using the Sync job. This has worked so far. In SOGo all folders and emails are displayed correctly. The MailCow mailboxes have now been integrated into Outlook via Activsync. Inboxes and sent mail are synchronized correctly.
However, the contents of all other folders and subfolders that were already created are not synchronized via Activsync. You only see the empty folders.
Has anyone had the same problem and possibly a solution?
Check if outlook does not have a filter set.. I noticed that too when testing with outlook. It will tell you on the bottom of the screen below below the folder list pane.
