Hi, first of all nice to meet you Guy’s.
I have some trouble setting um Borgbackup, I was following the guide here : https://mailcow.github.io/mailcow-dockerized-docs/third_party/third_party-borgmatic/
I did set up the docker-compose.override.yml
version: '2.1'
services:
borgmatic-mailcow:
image: ghcr.io/borgmatic-collective/borgmatic
hostname: mailcow
restart: always
dns: ${IPV4_NETWORK:-172.22.1}.254
volumes:
- vmail-vol-1:/mnt/source/vmail:ro
- crypt-vol-1:/mnt/source/crypt:ro
- redis-vol-1:/mnt/source/redis:ro,z
- rspamd-vol-1:/mnt/source/rspamd:ro,z
- postfix-vol-1:/mnt/source/postfix:ro,z
- mysql-socket-vol-1:/var/run/mysqld/:z
- borg-config-vol-1:/root/.config/borg:Z
- borg-cache-vol-1:/root/.cache/borg:Z
- ./data/conf/borgmatic/etc:/etc/borgmatic.d:Z
- ./data/conf/borgmatic/ssh:/root/.ssh:Z
environment:
- TZ=${TZ}
- BORG_PASSPHRASE=YouBetterPutSomethingRealGoodHere
networks:
mailcow-network:
aliases:
- borgmatic
volumes:
borg-cache-vol-1:
borg-config-vol-1:
Of course, I did change the BORG_PASSPHRASE
and this is how my config.yaml look’s :
source mailcow.conf
cat <<EOF > data/conf/borgmatic/etc/config.yaml
source_directories:
- /mnt/source
repositories:
- u309913-sub3@u309913.your-storagebox.de:23:mailcow
exclude_patterns:
- '/mnt/source/postfix/public/'
- '/mnt/source/postfix/private/'
- '/mnt/source/rspamd/rspamd.sock'
retention:
keep_hourly: 24
keep_daily: 7
keep_weekly: 4
keep_monthly: 6
prefix: ""
hooks:
mysql_databases:
- name: ${DBNAME}
username: ${DBUSER}
password: ${DBPASS}
options: --default-character-set=utf8mb4
EOF
I’m using a storage box from Hetzner for backup’s I have my ssh key’s in data/conf/borgmatic/ssh
but when i try docker-compose exec borgmatic-mailcow borgmatic init --encryption repokey-blake2
i just get:
/etc/borgmatic/config.yaml /etc/borgmatic.d /root/.config/borgmatic/config.yaml /root/.config/borgmatic.d: No valid configuration files found
summary:
/etc/borgmatic.d/config.yaml: Error parsing configuration file
An error occurred while parsing a configuration file at /etc/borgmatic.d/config.yaml:
mapping values are not allowed in this context
in "/etc/borgmatic.d/config.yaml", line 3, column 9
Need some help? https://torsion.org/borgmatic/#issues
Someone can help me?
