Hello,
I have included the calendar in my iPhone and created an appointment.
I added the location there and enabled the hints.
Unfortunately, I can not set it to remind me when I should leave.
The error message is: “Hint to set off are not available, because Calendar does not have access to your exact location.”
I have enabled the location though.
    • Best Answerset by Nlmyr
    I solved it by myself.
    Resetted the location settings.
