I suddenly get the following error message when trying to log into the Mailcow web interface as “admin” when authenticating with FIDO:
Fehlercode: InvalidStateError: An attempt was made to use an object that is not, or is no longer, usable - (bei persistierendem Fehler, bitte Browserfenster neu laden)
I have saved several Fidosticks from different manufacturers for the admin user, but I get the same result for all of them.
Does anyone have an idea how to fix this?
Is there a way to disable FIDO authentication from the command line?
any help is welcome
regards
Edit: all FIDO-Sticks are FIDO2
