• rma
      Moolevel 0
    Guten Morgen,
    mein Netfilter Container startet nicht, könnte der Fehler etwas mit ipv6 zutun haben?
    ERROR: for mailcowdockerized_netfilter-mailcow_1 Cannot start service netfilter-mailcow: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: process_linux.go:508: setting cgroup config for procHooks process caused: resulting devices cgroup doesn’t match target mode: unknown
    ERROR: for netfilter-mailcow Cannot start service netfilter-mailcow: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: process_linux.go:508: setting cgroup config for procHooks process caused: resulting devices cgroup doesn’t match target mode: unknown
    ERROR: Encountered errors while bringing up the project.
    Hatte jemand schonmal die gleiche Fehlermeldung und kann von der Lösung berichten?
    Ich freue mich über jede Antwort!
