Actually, I figured out something, but got stuck on another problem…
First, I disabled IPv6 according to documentation (because I don’t have it).
Then I run these commands:
cd /opt/mailcow-dockerized
touch data/assets/ssl/force_renew
docker-compose restart acme-mailcow
When I run docker-compose logs --tail=200 -f acme-mailcow I get this error:
acme-mailcow_1 | OK
acme-mailcow_1 | Thu Feb 10 16:45:23 CET 2022 - Initializing, please wait...
acme-mailcow_1 | Thu Feb 10 16:45:23 CET 2022 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow_1 | Thu Feb 10 16:45:23 CET 2022 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow_1 | Thu Feb 10 16:45:23 CET 2022 - Detecting IP addresses...
acme-mailcow_1 | Thu Feb 10 16:45:32 CET 2022 - OK: 185.58.xxx.xxx, 0000:0000:0000:0000:0000:0000:0000:0000
acme-mailcow_1 | Thu Feb 10 16:45:33 CET 2022 - Found A record for autodiscover.mydomain.mk: 185.58.xxx.xxx
acme-mailcow_1 | Thu Feb 10 16:47:42 CET 2022 - Confirmed A record with IP 185.58.xxx.xxx, but HTTP validation failed
acme-mailcow_1 | Thu Feb 10 16:47:42 CET 2022 - Found A record for autoconfig.mydomain.mk: 185.58.xxx.xxx
acme-mailcow_1 | Thu Feb 10 16:49:53 CET 2022 - Confirmed A record with IP 185.58.xxx.xxx, but HTTP validation failed
acme-mailcow_1 | Thu Feb 10 16:49:53 CET 2022 - Found A record for mail.mydomain.mk: 185.58.180.221
acme-mailcow_1 | Thu Feb 10 16:52:04 CET 2022 - Confirmed A record with IP 185.58.xxx.xxx, but HTTP validation failed
acme-mailcow_1 | Thu Feb 10 16:52:04 CET 2022 - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
acme-mailcow_1 | Thu Feb 10 16:52:04 CET 2022 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow_1 | OK
Also, port 80 is accessible from outside, I can verify it with curl http://185.58.xxx.xxx or curl http://mail.mydomain.mk (the same is true for port 443).
Any idea?
