Thanks for your reaction! Sure I can give you the acme container logs. I have replaced parts of he ipv6 address and ip4 address for security reasons. I have replaced my maildomainname with example.com
[docker-compose logs –tail=200 -f acme-mailcow](https://)
cme-mailcow_1 | Sat Dec 18 21:34:35 CET 2021 - Waiting for Docker API…
acme-mailcow_1 | Sat Dec 18 21:34:35 CET 2021 - Docker API OK
acme-mailcow_1 | Sat Dec 18 21:34:35 CET 2021 - Waiting for Postfix…
acme-mailcow_1 | Sat Dec 18 21:34:35 CET 2021 - Postfix OK
acme-mailcow_1 | Sat Dec 18 21:34:36 CET 2021 - Waiting for Dovecot…
acme-mailcow_1 | Sat Dec 18 21:34:36 CET 2021 - Dovecot OK
acme-mailcow_1 | Sat Dec 18 21:34:36 CET 2021 - Waiting for database…
acme-mailcow_1 | Sat Dec 18 21:34:36 CET 2021 - Database OK
acme-mailcow_1 | Sat Dec 18 21:34:36 CET 2021 - Waiting for Nginx…
acme-mailcow_1 | Sat Dec 18 21:34:37 CET 2021 - Nginx OK
acme-mailcow_1 | Sat Dec 18 21:34:37 CET 2021 - Waiting for resolver…
acme-mailcow_1 | Sat Dec 18 21:34:37 CET 2021 - Resolver OK
acme-mailcow_1 | Sat Dec 18 21:34:37 CET 2021 - Waiting for domain table…
acme-mailcow_1 | OK
acme-mailcow_1 | Sat Dec 18 21:34:39 CET 2021 - Initializing, please wait…
acme-mailcow_1 | unable to load certificate
acme-mailcow_1 | 139944729881416:error:0909006C😛EM routines:get_name:no start line:crypto/pem/pem_lib.c:745:Expecting: TRUSTED CERTIFICATE
acme-mailcow_1 | 139706598972232:error:0909006C😛EM routines:get_name:no start line:crypto/pem/pem_lib.c:745:Expecting: TRUSTED CERTIFICATE
acme-mailcow_1 | Sat Dec 18 21:35:01 CET 2021 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow_1 | Sat Dec 18 21:35:01 CET 2021 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow_1 | Sat Dec 18 21:35:01 CET 2021 - Detecting IP addresses…
acme-mailcow_1 | Sat Dec 18 21:35:01 CET 2021 - OK: 21.22.23.24, 2a01:db8:c010:a2eb::1
acme-mailcow_1 | Sat Dec 18 21:35:01 CET 2021 - No A or AAAA record found for hostname autodiscover.bdpq.nl
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Found A record for autoconfig.example.com: example.com.example.com
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Cannot match your IP 21.22.23.24 against hostname autoconfig.example.com (DNS returned example.com.example.com.)
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Found AAAA record for mail.example.coml: 2a01:db8:c010:a2eb:: - skipping A record check
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Cannot match your IP 2a01:db8:c010:a2eb:0000:0000:0000:0001 against hostname mail.example.com (DNS returned 2a01:db8:c010:a2eb:0000:0000:0000:0000)
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Cannot validate any hostnames, skipping Let’s Encrypt for 1 hour.
acme-mailcow_1 | Sat Dec 18 21:35:02 CET 2021 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow_1 | OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for Docker API…
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Docker API OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for Postfix…
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Postfix OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for Dovecot…
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Dovecot OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for database…
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Database OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for Nginx…
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Nginx OK
acme-mailcow_1 | Sat Dec 18 22:35:02 CET 2021 - Waiting for resolver…
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Resolver OK
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Waiting for domain table…
acme-mailcow_1 | OK
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Initializing, please wait…
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Using existing domain rsa key /var/lib/acme/acme/key.pem
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
acme-mailcow_1 | Sat Dec 18 22:35:03 CET 2021 - Detecting IP addresses…
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - OK: 21.22.23.24, 2a01:db8:c010:a2eb::1
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - No A or AAAA record found for hostname autodiscover.example.com
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - Found A record for autoconfig.example.com: example.com.example.com
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - Cannot match your IP 21.22.23.24 against hostname autoconfig.example.com (DNS returned example.com.example.com.)
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - Found AAAA record for mail.example.com: 2a01:db8:c010:a2eb:: - skipping A record check
acme-mailcow_1 | Sat Dec 18 22:35:04 CET 2021 - Cannot match your IP 2a01:db8:c010:a2eb:0000:0000:0000:0001 against hostname mail.bdpq.nl (DNS returned 2a01:db8:c010:a2eb:0000:0000:0000:0000)
acme-mailcow_1 | Sat Dec 18 23:35:06 CET 2021 - Cannot validate any hostnames, skipping Let’s Encrypt for 1 hour.
acme-mailcow_1 | Sat Dec 18 23:35:06 CET 2021 - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
acme-mailcow_1 | OK
