Hi.
I’ve got 2FA problem. From one day to the other I couldn’t use mit 2FA with my Yubikey on my admin account anymore. Maybe the problem is my https connection, but that’s not the point. I use these two command strings
1. source mailcow.conf
2. docker-compose exec mysql-mailcow mysql -u${DBUSER} -p${DBPASS} ${DBNAME} -e "DELETE FROM tfa WHERE username='YOUR_USERNAME';"
and now I could not connect to my mailserver at all. No IMAP, no https, no nothing. 🙁
In portainer I see that the dockers are running.
In the log files of nginx ist see this error, but I don’t know if this has a relation to this problem now?
2020/05/03 17:02:07 [emerg] 13#13: SSL_CTX_use_PrivateKey("/etc/ssl/mail/key.pem") failed (SSL: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch) nginx: [emerg] SSL_CTX_use_PrivateKey("/etc/ssl/mail/key.pem") failed (SSL: error:0B080074:x509 certificate routines:X509_check_private_key:key values mismatch)
In the dovecot log files is see also errors:
May 3 17:25:45 pboenig dovecot: imap-login: Error: Failed to initialize SSL server context: Can't load SSL private key: Key is for a different cert than ssl_cert: user=<>, rip=192.168.178.66, lip=172.22.1.250
May 3 17:25:45 pboenig dovecot: imap-login: Disconnected: TLS initialization failed. (no auth attempts in 0 secs): user=<>, rip=192.168.178.66, lip=172.22.1.250
I also used the helper script to reset the admin account but no success.
I don’t know what to do. 🙁
